96 F250 5.8 oil filler cap
Old 08-31-2015, 08:42 PM
pcurtice's Avatar
pcurtice
pcurtice is offline
The oil filler cap on my truck fell apart tonight. It was the type that clicked upon tightening. I believe it is a motorcraft part. I noticed there was a spring located inside of it. Is this some type of pressure release mechanism or just a style to prevent over tightening? Is this a unique oil filler cap for this engine, 5.8? I will have to order one off the internet or dealership but in the meanwhile all I can find locally are filler caps that don't have the clicking mechanism. Would any issues present itself if I used one of these oil filler caps for a few days of driving until I received the right cap. Thanks for your time.
Old 08-31-2015, 09:18 PM
choate's Avatar
choate
choate is offline
I'm not 100% sure but I have a 351 and I don't think my clicks. Just turns and stops. I can check in the morning if you get no more replies tonight
Old 08-31-2015, 09:25 PM
Claybeaux232's Avatar
Claybeaux232
Claybeaux232 is offline
You should be fine running a regular non clickity cap, your engine ventilation should be via a tube from your intake hose to the drivers side valve cover, and from your pass valve cover to the upper intake via pcv valve and associated tubing.
Old 09-01-2015, 08:41 AM
pcurtice's Avatar
pcurtice
pcurtice is offline
Thanks for the response. I would assume there is a reason for a filler cap of that style and I will replace it with the same style. I will check all vent tubing and PCV and use the non clicking/breathing style cap until my new cap arrives. Thanks again.
Madsan
15
05-18-2020 01:23 PM
Rode Hard
24
04-24-2017 07:04 PM
Spktyr
02-16-2014 07:57 PM
Thumper19
08-24-2012 01:09 AM
elinmon1976
01-10-2010 11:27 AM
Quick Reply: 96 F250 5.8 oil filler cap
