Odd problems engine shutting off
Old Aug 31, 2015 | 03:05 PM
cgholson192's Avatar
cgholson192
Exclamation Odd problems engine shutting off
Please help, I have a 2003 Excursion 6.0 with edge juice with attitude
While driving first thing in the morning runs like a champ, as the engine warms up I start seeing the exhaust temps lower to 88-94, then I start getting over boost code with monitor reading of 41psi, then the Edge monitor screen will go blank, then the STALL... The excursion with start right back up but the shut off immediately. Wait 20-30 minutes in the shade and will start back up and run again poorly missing almost like turning the key off and back on... Then the next morning start all over again. Any ideas ????
I'm thinking bad FICM or bad PMC over heating.. ??
Old Aug 31, 2015 | 03:31 PM
evan1242's Avatar
evan1242
is the juice with attitude the one thats plugged into everything, or just the OBDII port?
your best bet will be to return to stock and start from there.
Old Aug 31, 2015 | 03:41 PM
cgholson192
Edge I have doesn't plug into OBD just PCM and I believe it is the MAP. I have completely removed it and No change.
Old Aug 31, 2015 | 04:30 PM
WatsonR's Avatar
WatsonR
What's the ICP reading when she dies?
FICM readings of input and output?
Check your batteries and alternator.
Old Aug 31, 2015 | 04:52 PM
cgholson192
batteries and alternator are new have not been able to get ICP and FICM Reading at the point it dies, mainly trying to get off the side of the road... ha ha a little difficult with this big beast lifted on 35's... captured a lot of different readings when restarted and died again... voltage 78 Boost 102 FICM V 14.4-93.6 very odd readings that don't make much since, thinking either a short, ground issue, bad PCM, bad FICM just very odd readings RPM 10072 things like that. curious if anyone had any ideas before I throw a couple hundred out for a PCM.
Old Aug 31, 2015 | 05:12 PM
evan1242's Avatar
evan1242
again, with those readings i would remove the edge and return to a stock program so you have a known base to start with.
Old Aug 31, 2015 | 05:15 PM
dannyboy950's Avatar
dannyboy950
I would suspect the problem may be with what you are reading it with.
Those are all strange numbers for what you are reading sensor wise.
FICM's go out more often than PCM's but they do go out. Maybe 1 pcm to 10 FICM.
Old Aug 31, 2015 | 06:14 PM
cheezit's Avatar
cheezit
Do the glowplug light come on when it dies?
Old Aug 31, 2015 | 07:13 PM
cgholson192
I have not noticed the glowplug light coming on when it dies. I will keep a eye on it. What would that indicate ?
Old Aug 31, 2015 | 07:32 PM
cheezit's Avatar
cheezit
Indicates a pcm reset.
Old Sep 1, 2015 | 03:44 AM
87crewdually's Avatar
87crewdually
Review his post #3.
OP, Have you checked for codes? Can you monitor sync? Monitor both Cam/Crank sync and PCM/FICM sync. See if it's losing one or the other or both. Also, next time it does it, try unplugging EBP sensor and then try to restart it.
greagin
Apr 8, 2007 09:28 PM
GloryToTheSouthland
Computer Chips & Tuners
Jan 4, 2007 06:42 PM
devilclawz
2004 - 2008 F150
Mar 8, 2006 03:10 PM
s2gots
May 26, 2005 07:53 AM
