stumples at start
Old May 20, 2005 | 09:17 PM
s2gots's Avatar
s2gots
stumples at start
My CEL has been on for a few days, the trucks going in monday..but yesterday and today I have noticed a few times that when I start the truck, it hesitates and stumbles for a few seconds at start up, and then its fine. Once after this happened, I shut it down, waited a few seconds, started up, and it did it again, but I repeated the process, and started fine the third time.
Old May 21, 2005 | 07:19 AM
Maxium4x4's Avatar
Maxium4x4
After market flash program installed by any chance?
Old May 21, 2005 | 05:01 PM
s2gots's Avatar
s2gots
no, I had the edge/juice combo, but removed it.
Old May 22, 2005 | 12:41 AM
Maxium4x4's Avatar
Maxium4x4
Do you have the stumble now since you removed the Edge? I had a slight stumble with calibration not being right. Could be your Edge is giving you a problem.
Old May 22, 2005 | 12:57 AM
s2gots's Avatar
s2gots
No, this has happened a few days after removing the edge...never happened with it.
Old May 22, 2005 | 01:05 AM
Maxium4x4's Avatar
Maxium4x4
Well see what the tech finds.....must be something out of calibration. Doubt if anything is serious...probably a sensor or EGR.
Old May 23, 2005 | 10:47 PM
Todder's Avatar
Todder
My truck kinda did that when it had a stock tune in it, but with my SCT tune its never done it again.
Old May 24, 2005 | 07:27 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
s2 have you had your truck flashed?
Old May 24, 2005 | 10:33 AM
Mark Oomkes's Avatar
Mark Oomkes
Does the 6.0 have a Cam Position Sensor like the 7.3?
Old May 24, 2005 | 01:51 PM
Maxium4x4's Avatar
Maxium4x4
Mark
The 6.0L has a Camshaft Position Sensor (CMP) and a Crankshaft Position Signal (CKP). The PCM monitors the values between the CMP and CKP. An error code would be present unlike the 7.3L and the CPS.
Old May 24, 2005 | 08:00 PM
s2gots's Avatar
s2gots
nope..never reflashed..still has the factory one from march of '04...Im sure thats going to change now as its at the dealer...As I was taking it there...when I was at stoplights, it would get loud, and then quiet..but rpms would stay the same...except after when it was quiet for about 10 seconds, the rpms would drop slightly, and then it would sort of pick itself up again, and be loud...well see what happens tomorros....
Old May 25, 2005 | 12:01 AM
jim6liter's Avatar
jim6liter
Mine gets louder and quieter when idleing also; and the rpms don't change.Even when driving at steady speeds like 40 or 30 the engine gets louder and quieter. It only seems to do it when its hot outside or if Ive been driving for an hour on the highway.Im in Phoenix so its hot now.Anyone have any ideas?Thanx, Jim
Old May 25, 2005 | 07:46 PM
s2gots's Avatar
s2gots
well the dealer figured out what the stumble was...bad egr sensor....but thats not the worst of it...found out my head gasket is leaking and so is the rear main...going back tuesday for who knows how long...they told me the engines gotta be pulled out...that sucks...big time...I wont have my beast for at least 2 weeks they said...is this about how long it takes??? Also, is it true that FMC does not pay for rental cars if your vehicle is out for a length of time??? Thats what Ive been told today and that really sucks, as this is my only vehicle...In my earlier chebby days, when my vehicle was out for more that two days I always got a rental....this bites on fords part...
Old May 26, 2005 | 07:53 AM
Maxium4x4's Avatar
Maxium4x4
Well you found your stumble and then some I guess. Not sure on the rental to give you an idea.
