T-19/BW 1345 Swap into a 69 F100 4WD?
on
Thinking about doing this. I have a line on a transmission and t-case out of an 84 diesel.
Has anyone put one of these into a bumpside? Does the early '80s T-19 mate to an FE bell housing?
Are there alignment issues between the BW 1345 and the Dana 44?
on
IIRC a T-19 is basically the same dimensionally as a T-18. Measure the 1345 TC as to width. You have a 33 1/2" wide frame so it might be too wide, but NP-203/205's were put in Dent F-250's up to 77, so if it is the same or narrower than a 205, it should fit. As to the Dana 21, I would chuck it as it is only a 1 speed TC.
Go to Advance Adapters and check out the T-18/NP-435 swap into EB's using the Bronco D-20. A D-21 is just like a D-20 IIRC.
on
Rich,
I agree the Dana 21 is not much use, but I don't really need much. It is a pavement truck these days. Mostly interested in shredding tires.
I'll crawl under and see how it would fit. The only specs I could find on the BW 1345 show it to be 23 inches wide, about 5 inches more than an NP 205.
I'm hoping we have an expert out there who knows this stuff. I'd like any combo of a T-19 and t-case that will fit easily.
I have a feeling the bolt pattern is different. The 7086 gasket that goes between the married T/C and tranny is a different part number between a Bump (Dana) and the 84 (NP). The 84 takes the same gasket as a Dent.
on
Thanks guys. Not a lot of knowledge out there about the F100 4WD, there were very few of them.
I think I can make a T19 and BW 1345 work, but am looking for some details on the size of the BW 1345. The info I have on it is a little suspect, claims it is 17.25 inches long (assume this means front to back), 23 wide, and 12 high. The Dana 21 is 7 inches long (not including the yokes), 8 tall, and 16 wide (based on my measurements).
That is a LOT bigger, but I might be able to make it work. Have to buy it to find out.
Mister_King
12-29-2014 04:08 AM
jeremychance
04-12-2011 09:23 PM
RCook527
02-03-2006 12:52 AM
f100plow
01-26-2005 10:56 AM
