69 f-250 power brake conversion
well I got my truck back from a the shop today. I had the brakes converted to a power booster and master cylinder as far as stopping power, it stops far better. The issue I now have is there is very little travel in the pedal, before the brakes completely stop. anyone here have a suggestion ? I know it is probably in the set up somewhere.
I like the guy that did the upgrade, so this is more for my knowledge when I take it back.
Thanks
Thanks
Thanks
Thanks
The stock MC bore diameter for all wheel drums, power or manual brakes, was 1.00".
The MC for optional front discs on a '69 F250 with power brakes was 1.125". It's POSSIBLE a 1-1/8" bore MC was installed instead of a 1.00" bore MC.
A larger bore MC will have a very firm pedal with little pedal travel. A large diameter MC will move more fluid volumn but, will produce less output pressure.
A smaller bore MC will move a lesser volumn of fluid, will have more pedal travel but, will produce more output pressure for the same amount of force applied on the brake pedal.
Another possibility is there's a defect with the booster. Problems with a vacuum booster often result in a very stiff brake pedal.
Without seeing the booster, I don't know if it has an adjustable input rod (the rod from the brake pedal pin to the back of the booster)?
The tip of the booster output rod should be adjustable though. With the brake pedal in a static position (not being applied), there should be a very small gap (.005"-.010") between the tip of the booster output rod and the back of the primary piston of the MC.
If the rod is adjusted too far out, it will keep the MC partially applied, even when you aren't pressing down on the brake pedal. This will make the brakes drag and can make them lockup after driving a short distance.
If there's too much gap between the booster output rod and the MC, you'll have a long travel on the brake pedal before any significant brake force is applied to the brakes. It doesn't sound like the rod adjustment is the problem but, without actually being able to see/lay hands on the truck, it's hard to say for sure exactly where the problem is.
andrewscofield
09-11-2019 10:55 AM
49willard
11-07-2015 07:06 AM
threewhln
08-04-2013 07:49 PM
f100jim
07-16-2007 05:43 PM
norvillebob
11-17-2006 02:22 PM
