Hellwig noises
Old Aug 29, 2015 | 02:15 PM
pgguru's Avatar
pgguru
Hellwig noises
After 2 months my hellwig sway bar is starting to make a lot of noise I've checked to make sure everything is still tight and it is.
It does it on sharp corners and breaking
Any ideas
Thanks
Old Aug 29, 2015 | 05:29 PM
pirate4x4_camo's Avatar
pirate4x4_camo
Take it apart and apply some anti seize between the bushing and bar and the bolt and the bushing sleeve, In other works put some lubrication between the moving parts.
Old Aug 29, 2015 | 05:47 PM
05MilMachine's Avatar
05MilMachine
Make sure the end links are not contacting anything also. Did you use that silicone lube the bar comes with everywhere?
shaferz
Jan 25, 2011 07:51 PM
John7894
Jan 17, 2009 09:43 PM
smokinbucs
1997 - 2003 F150
Feb 3, 2007 03:02 AM
Munkey
Aug 7, 2006 02:47 PM
GotLift
Sep 10, 2005 01:01 AM
