Steering wheel shake
Old Aug 30, 2015 | 07:48 AM
KDAVID1's Avatar
KDAVID1
Originally Posted by twigsV10
What are you running for tires? My 06 had the same steering shutter on high-speed curves that you described with fierce attitude MTs. They were pretty good tires from my experience other then they were very stiff, New shocks and steering stabilizer helped but didn't completely eliminate it but it completely went away after changing to a different brand of tires. The i80/i35 cloverleaf used to be a white knuckle ride at 45 mph now I can run as fast as I want and the only hop and skip is from the rear end jumping on the bumps.
I'd recommend checking the steering components for wear then replace the shocks if they're old and then look at tires.
Stock tires 18" wheels. Transforce I think or something like that.
Originally Posted by Rusty Axlerod
A couple years ago I had a steering wheel wobble. Track bar bushing was shot.
https://www.ford-trucks.com/forums/1...r-bushing.html
Will take a look at that as well. I imagine all the rubber under there is timed out. I do have noticable outside wear on the passenger side and have a slight pull to the right as well.
leeb_0001
Mar 12, 2019 09:35 PM
FourWheel
16
Apr 1, 2009 03:08 AM
Ranger Louie
Mar 3, 2008 05:36 PM
GasMonkey
Sep 22, 2004 11:26 PM
tonyevans69
1983 - 2012 Ranger & B-Series
Aug 27, 2002 09:40 PM
