Looking for Programmer for E-150
Old Aug 25, 2015 | 07:30 AM
Jeremy Lembo's Avatar
Jeremy Lembo
Hey there Towing people;
I have a 2011 E-150 and I tow a trailer with it from time to time and well... the performance of this van with a trailer is less than desirable. I looked at all the Programmers out there like SCT and Edge, etc... and None of them have a program for the year/model van. Does anyone out there have experience with a programmer for this van?
Any information is helpful.
At this point, I am looking at getting the SCT Livewire TS+ and then spending anywhere from $300 (minimum quoted price) to $1200 to have a program written! At that point, unplugging an O2 sensor so it runs rich is a better option.
Old Aug 25, 2015 | 03:51 PM
senix's Avatar
senix
I moved this to the van section. I think this maybe a better source for programmers that everyone maybe using.
What size motor do you have? Don't know if there are options or just one motor.
Old Aug 25, 2015 | 09:00 PM
Conanski's Avatar
Conanski
Unless your van has a turbo diesel motor a tuner is a complete waste of money because you cannot program in more torque from a non turbo gas engine.. it is what it is so your options would be change the axle gearing or change the tow vehicle.
Old Aug 26, 2015 | 05:45 AM
Jeremy Lembo
I disagree. Though you can not program more torque, you can program shift points, fuel delivery, spark advance, etc. it all helps while towing. For some reason, the manufacturers do not have a standard program for this vehicle. It has one for the F-150 for 2010 with the same Engine/Tranny combo. I am sure Demand is the reason.
At this point, my quick fix is to disconnect an O2 Sensor and then it runs in a rich condition and there is a noticeable difference in power. I can get to speed limit quicker, hold it here and the transmission does not shift as much.
Old Aug 27, 2015 | 06:54 AM
JWA's Avatar
JWA
Before you spend too little for a "will fit" program or too much on something custom-made look at this thread: https://www.ford-trucks.com/forums/9...ky-thread.html
That thread is mostly about the V10 motor however I'm assuming you have a gasoline V8 Mike can/will write a program pretty much tailored to your exact needs---in fact you receive up to 3 tunes plus device for under $500.
The imparted value doesn't stop there though. Once you've had time testing one of his tunes if it needs tweaking to better suit you that's pretty much included in the price. He knows these engines and their strategies as well as anyone but the willingness to support his products after the sale is absolutely amazing to me. Others agree as you can see in that above-thread.
I hope this gets you pointed in the right direction.
Old Aug 28, 2015 | 06:19 AM
Jeremy Lembo
Thanks for that!
I will look into that link. I hope it works out and $500 is reasonable as well!
Schneiderman07
34
Oct 31, 2022 01:49 PM
Dw89xj
Computer Chips & Tuners
Nov 29, 2019 10:20 AM
leardvr
24
Nov 22, 2005 10:11 AM
benniemac
Jul 6, 2004 08:34 PM
Jimjdb1
Mar 27, 2002 07:18 PM
