Changing CAP and ROTOR
Old Feb 27, 2002 | 06:33 AM
westapher's Avatar
westapher
Old Mar 1, 2002 | 09:42 AM
WB9PRG's Avatar
WB9PRG
When I change the cap and rotor should I use any grease on the cap contact points? Or should I install them as they are right out of the box??
Thanks,
Gene
Old Mar 1, 2002 | 09:49 AM
CUWaldo's Avatar
CUWaldo
Install them as they are right out of the box. Grease is a big no-no. The rotor doesn't actually contact the 'contacts' in the cap anyhow.
Tim
Old Mar 1, 2002 | 09:54 AM
WB9PRG's Avatar
WB9PRG
Thanks Tim,
I will do as you say.
Gene
Old Mar 1, 2002 | 11:33 AM
GammaDriver's Avatar
GammaDriver
You can use dielectric grease on the center spring contact of the rotor, and on all the outside posts for the plugs wires though.
Old Mar 1, 2002 | 04:27 PM
WB9PRG's Avatar
WB9PRG
The job went well!
The firing order in the chilton manual was not the same as the writings on the engine compartment on my truck.
1996 F150 4X4 EXT CAB 302 V8 FIRING ORDER 13726548
Thanks for the help !!!!
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
