What am I missing?
Old Aug 22, 2015 | 11:41 AM
Sxy_annette902's Avatar
Sxy_annette902
What am I missing?
94 f250 w the turbo idi. Put a new(used) gas tank to replace the stock one that was falling apart. Right away the truck would start, drive then get a big burst of power and die. Ok, got air. Did the valve on the fuel filter, it's getting straight fuel finally, cracked the front 2 injectors, one each bank, fuel finally, but it takes forever to start and if it does, it stumbles and dies. The tank is on the ground w clear hoses to what's going on w that but looks fine. I'm not sure what I'm missing.
Old Aug 22, 2015 | 06:10 PM
PlumCrazy7's Avatar
PlumCrazy7
How much fuel is in the tank and what shape was the sending unit in? If your pickup tube lost the little black bowl then you cant get fuel under a quarter tank. If you have a piece of rubber hose without a relief cut then the hose can suck to the bottom of the tank and cut off fuel.
Old Aug 22, 2015 | 08:56 PM
Macrobb's Avatar
Macrobb
Check your low pressure fuel pump; it's probably dying. They're only $25-30, so no big deal.
Old Aug 23, 2015 | 12:42 PM
Sxy_annette902
Got it!
Finally figured it out. The pick up tube in the tank (wrong name I'm sure) had a crack towards the top. Got a new one and fixed the problem. The crack wasn't big but I went over every step and after a few hours, finally found it
Old Aug 24, 2015 | 06:46 PM
typefour's Avatar
typefour
Your description is perfectly accurate.
sloppyslim16
19
May 15, 2015 05:46 PM
F250_JR
43
Feb 17, 2014 09:14 AM
wdhille
Sep 30, 2009 07:09 AM
lawnguy2003
Feb 1, 2004 05:53 PM
Sun
17
Mar 8, 2003 08:54 AM
