Driving through a fairly heavy thunderstorm (hail, traffic stopping on the freeway heavy), I noticed a bit of moisture in the cab.
I've seen a little seepage on the passenger side before, but the wetness around the gas pedal is new.
Also look for a hole in the water ducting in the cowl
Or a rust hole in your cowl. Mine does that and it's cause the firewall rusted out behind the cowl, I'll fix it when the weather cools off. And this truck has lived in FL it's entire life so even if yours ain't been up north it could still be rust.
This truck has been in Wisconsin its whole life, so there is rust.
I figure on taking a look-see in the cowl area first, and hopefully drafting my son to hose down the outside of the truck to see just where it is coming in.
