standpipe / dummy plug question
Old Aug 20, 2015 | 12:05 PM
MLKE1688's Avatar
MLKE1688
Hey guys I'm new to the forums but had a quick question.
so i'm replacing the hpop,ipr,icp,oil cooler and a bunch of other things on my truck ( 2007 Ford F-450 6.0l ) cause I had a no start when hot condition so I figured I would just do it all in one shot and get it out of the way.
well after all of it was replaced I did a pressure test on the high pressure oil system and still had a small leak so I popped the valve covers off and pulled the dummy plugs and ( front and rear ) and the rear ones didn't have the standpipes on them ?? has anyone ever ran in to that before ??.
I've done a ton of work on these 6.0l's ( I'm a master certified technician ) but have never seen one of these without standpipes? someone has been in there before me and replaced the dummy plugs ( they were the 12mm plugs and the seals were torn so that was probably my leak I had cause it wasn't a very big one ) but the rear were the 10mm with no tubes attached and they aren't down in the motor.
Any info is appreciated
Thanks.
Old Aug 20, 2015 | 12:19 PM
npccpartsman's Avatar
npccpartsman
It wouldn't run without standpipes since they feed HPO from the pump to the injectors. Are you sure 1/2 of the standpipe isn't still down in the motor?
Old Aug 20, 2015 | 06:11 PM
87crewdually's Avatar
87crewdually
Like Tim said probably half the standpipe was still in the head.
konchryboy
Jul 11, 2017 04:47 AM
MLKE1688
Aug 21, 2015 06:35 PM
mototrig
Mar 5, 2013 02:26 PM
Jarhead97
Oct 23, 2012 09:38 PM
meierw1
16
Feb 15, 2012 01:28 PM
