Gas tank drop question
Old Aug 19, 2015 | 07:53 PM
mikerogers56's Avatar
mikerogers56
I am going to replace the tank on my 78 F100 2wd. It has a 19 gallon tank with a line going into it for the charcoal canister. How does that line disconnect from the tank? I'm not going to remove the bed and that is the only thing I can't see how to disconnect.
Thanks
Old Aug 19, 2015 | 08:01 PM
Blue and White's Avatar
Blue and White
If you get the fill hoses and fuel supply disconnected, you should be able to lower it a foot or so and get at the evap hose.
Old Aug 19, 2015 | 08:13 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
That fuel tank has a press in valve (EEC) on the top center of the tank and that rubber line just pushes on and should run up the frame rail and to the 2 white charcoal canisters on the passenger side frame rail or on the r/s side of the eng compartment below the alternator to a round pot style canister.
There are two differences between the tanks. Tanks with EEC have a hole in the top center of the tank. A rubber grommet and check valve are pressed into the hole. A line goes from the check valve along the inside of the passenger side frame rail to the engine compartment where it hooks up to a charcoal canister. Non-EEC tanks don't have this hole. The other difference is the nipple for the breather line that is located right next to the nipple for the filler hose is located 180 degrees opposite.
If you are going from an EEC tank to a non-EEC tank you must also change the fuel cap to a vented style. The EEC tanks are vented through the EEC system and use a sealed fuel cap. Non-EEC tanks vent through the fuel filler cap.
If you run a non-EEC tank and a sealed cap the minimum is you'll have fuel starvation problems, at worst a collapsed fuel tank.
Old Aug 19, 2015 | 08:25 PM
77&79F250's Avatar
77&79F250
Disconnect the wire that goes to the fuel sending unit at the tank. Ground that wire to the frame, making sure the frame is clean. Turn the ignition to the "run" position and watch the fuel gauge. If the gauge swings all the way to full, either the sending unit itself is bad or it has a bad ground. If the gauge stays on empty then either the gauge is bad or there is a wiring problem.
To pop the plug off for the test, you can barely get up in there with your head and see the plug. While looking at it, VERY CAREFULLY use a screwdriver to pry it off. AND I MEAN VERY CAREFULLY. It is only pushed on like a 1/8". This is only if you can’t get it with your hands.
Once you have done the test (above) and decide it’s the sending unit. And you have cleaned the ground and that did not work. Then disconnect the ground again and fuel line and read on….
If you can't get either one disconnected, no worries you will have a little more room once the tank is dropped down a little. But make sure you have some wire slack in the plug connector.
Run the tank dry or almost or siphon it empty, I would not do it with ½ a tank of fuel, but if you just have to, just use a big floor jack and a piece of 2x2 plywood. It’s not heavy at all, unless you have it full or 1/2 full of gas. JUST DRAIN THE TANK!
Loosen the filler and vent hose clamps at the tank end and maybe you can pop the lines off? But most of the time you have to just loosen the clamps and wait till the tank is about out.
With the jack in place, or not, just loosen the hdwr (2 bolts) on the front straps, and remove the tank straps aft hdwr all together, then swing the straps out of your way.
Slide the tank to the dvrs side about 1/2" and then pull out or let the passenger side come out of the frame. Then disconnect the elec connector and eng feed fuel line if you could not get to them earlier.
Then slide it as far as you can to the right and pop off the filler/vent lines. Sometime you need to carefully put a flat tip screwdriver in between the rubber hose and the tank to break it loose. The filler neck and vent lines get stuck to the metal pretty good sometimes.
Once the tank is removed there is a lock ring that comes off with a screwdriver or punch, look for a small tab that has been bent over to lock it. Un-bend it, tap off the lock ring, remove the sending unit.
Insp the underside of the tank where the support straps rest, lots of dirt and moisture build up there, and that causes the bottom side corners to rust out. You can also come reinstall time replace the anti-chaff material. Old 2" ratchet strap work great, glued to the support straps.
Insp the inside of the tank, might be a great time to replace it all together? Before you reinstall anything connect the electric connection and ground to the sending unit. Wire it up under the truck so it is not hanging by the connection. And with the key in the 1st (on position) you should be able to move the float arm and see a difference in your gauge?? It is always easier to do this with a helper.....
Also before install, paint the complete tank with some good paint. Even spray on bed liner or undercoating??
Zia-Lycan
Large Truck
Nov 8, 2017 11:29 PM
EightGodzillas
May 16, 2017 03:29 PM
ktm4012
15
Feb 25, 2016 03:10 PM
Zachthemoo2
Dec 13, 2014 10:29 PM
Skate138
Jun 12, 2012 06:09 AM
