spring gap?
Old Aug 19, 2015 | 10:21 AM
g00d4me's Avatar
g00d4me
spring gap?
Just had my new springs put on and I'm wondering if there's supposed to be a gap at the top of the spring and the metal bracket that holds it in?
Old Aug 19, 2015 | 10:55 AM
pirate4x4_camo's Avatar
pirate4x4_camo
It doesn't hold it in as much as it keeps it from falling out when you put it on a lift. It will retain it the way it is but if it bugs you just rotate the spring to the right until the gap is gone. You will have to put it on a lift or jack from the frame so the wheel is hanging free
Old Aug 19, 2015 | 10:57 AM
Skip1970's Avatar
Skip1970
need to bend bracket or put hose over spring, gaps in suspension components are not usually good
Old Aug 19, 2015 | 01:05 PM
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
In this case it's not a big deal, all it does is keep the spring in place should the suspension flex to max droop. It serves no other purpose than that.
1024F250
Aug 7, 2018 06:09 PM
Treacy
Dec 14, 2015 06:56 PM
romara
Feb 26, 2009 08:08 PM
99sbm
Dec 20, 2008 01:43 PM
MMarty
Jun 16, 2006 06:52 PM
