cutting off in drive while at light
Old 08-18-2015, 09:09 PM
bigxdriver's Avatar
bigxdriver
bigxdriver is offline
Heyy guys need help, when im at stop light my truck cuts off while in drive, it idles low when cranks up, it sputters like its not getting gas, I already replaced IAC valve, cleaned throttle body & mass air flow sensor, I replaced fuel pump,fuel filter,all spark plugs & bad coil packs, check battery & alternator, checked all vacuum lines & every now & then the check engine light comes on with a p220 code: Output speed sensor which I replaced, what else could it be
Old 08-18-2015, 09:56 PM
Krazee Matt's Avatar
Krazee Matt
Krazee Matt is offline
Year and engine type would help out bud.
Just to verify, the OSS on the trans was replaced already?
Old 08-19-2015, 06:04 AM
bigxdriver's Avatar
bigxdriver
O sorry its a 2003 with 5.4Liter motor & yes OSS has been replaced
Old 08-19-2015, 04:56 PM
kennisonxgs's Avatar
kennisonxgs
kennisonxgs is offline
How did you test the alternator? I'd take a much closer look at that, if I were you.
Dalton Henderson
1997 - 2003 F150
07-19-2019 10:03 AM
jamull2852
Modular V8 (4.6L, 5.4L)
09-02-2013 04:25 AM
kdy72601
02-05-2009 04:22 PM
getnbz
1999 to 2016 Super Duty
09-01-2008 09:49 PM
gerald tompkins
06-12-2005 10:12 PM
Quick Reply: cutting off in drive while at light
