I installed a new MSD mechanical advance distributor in my 429. The distributor comes from the factory with a 21 degree advance stop. Then, it comes with other stop bushing that will increase the degrees of advance to 23, 25,or 28. It also has different springs to vary the rate of advance. I played with the springs, to where it is running very nicely. Any advice out there on whether I should play with the other stop bushings, and how to know what my maximum advance should be, other than trial and error?
This is going in large part depend on what you use the truck for and how you drive along with gear ratio, tire size, and horse power .. Generally speaking the more initial timing the better the lower end of the power band performs which one needs for what I call truck related duties (towing etc.) but this does sacrifice some top end performance .. If your not operating above 4500 rpm's you'll never notice .. For a working truck I like 34-36 total timing and all in by about 3300 rpm's .. If your going to work your truck it's better to stay safely away from detonation by making very small adjustments ..
Thank you, redroad. That was helpful. I will ramp up slowly to avoid detonation.
4:11, C6, 33" tires. I don't know the HP. Performer RPM heads & intake manifold. Comp Cams high tork cam, SVO roller rocker arms, 750 Holly single pump.
Some heavy loads, some hot rodding around; it just depends on the day. 7500' elevation to deal with, too.
