SRW to DRW conversion
Old Aug 15, 2015 | 03:59 AM
Vertrees's Avatar
Vertrees
I did a little digging, and could only find people doing DRW to SRW conversions. I had read an article a while back saying that the frame width's were actually different between the SRW and DRW trucks. I dont know if there was any truth to it, but they had a pretty lengthy article into it. Sounds odd to me though.....
I will try and find the article I read and post a link to it. My question is if this is the case what is the plausibility of converting over to DRW.
If the article I read is incorrect i assume it will just be a matter of new springs, hangers, and yoke size on the differential.
I had given up on the idea of converting my truck over to DRW due to the extensive cost of everything. I bought a set of H1 wheels and tires, and just assumed re-centering the wheels, but with the idea of just bolting them on as is, and the option to be able to just slap wheels and tires on to be a DRW sounds far more enticing.
Maybe I'm just going over bored with the whole thing though lol
Either way I'm probably replacing both axles to do my 4x4 conversion. I was strictly looking for 99-04 SRW axles with 3.73 gears. This was mainly due to cost. I can buy the newer body style axles as a set with the SD Dana 60 axle cheaper than I can buy one Dana 60 front. I may stay this course to keep costs low, but all at the same time I'm thinking might as well just set it up how I want it since I'm going to be going through all the trouble anyway........
Old Aug 15, 2015 | 05:37 AM
427 fordman's Avatar
427 fordman
Frame widths are the same, unless it's a cab and chassis truck. On them the frames are different along with the axle housings. If you get a drw housing out of a drw pickup truck it will bolt right in.
I put a drw housing out of an early 90's truck in mine. I used the 4.10's I had, but rebuilt the rest completely.
Last edited by tjc transport; Aug 15, 2015 at 06:23 AM. Reason: fixed it for you Darrrin
Old Aug 15, 2015 | 06:19 AM
Vertrees's Avatar
Vertrees
Originally Posted by 427 fordman
Frame widths are the same, unless it's a cab and chassis truck. On them the frames are different along with the axle housings. If you get a drw housing out of a drw truck it will bolt right in.
I appreciate the info! I thought it sounded a bit peculiar that they would be different.
Old Aug 15, 2015 | 06:21 AM
tjc transport's Avatar
tjc transport
i ain't rite
as
Darrin said, there are 2 different dually rears.
the F350 cab chassis rear has narrow spring perches to fit the 33 inch wide frame of the Cab chassis trucks.
the F-350 dual rear wheel pickup has a 36 inch wide frame and as such, the rear has 36 inch wide spring perches.
so all you really need to do is find a rear out of a dually pickup to stuff under there.
Old Aug 15, 2015 | 06:34 AM
Vertrees's Avatar
Vertrees
to be honest the cab and chassis truck didnt cross my mind at the time, but the article I read simply stated you could not convert any SRW to DRW with out fabricating the frame because the tires would rub on the inside.
I thought it sounded off the wall, and asked around a bit to people who couldnt give me an exact answer, but helped fuel my disbelief in the matter. I assumed the article was incorrect, but do to paranoia I figured I'd ask you all, because I hold a lot more faith in the guys on this forum.
Old Aug 15, 2015 | 08:04 AM
mechmagcn's Avatar
mechmagcn
How much difference is there in the width of the axle? Since I bought the '97 F350 for a parts truck I have been considering converting my '97 F250 4X4 to DRW.
Old Aug 15, 2015 | 09:19 AM
BBslider001's Avatar
BBslider001
No difference if out of the dually truck, as stated above. That would be cool. Not too many DRW 4x4s running around.
Old Aug 15, 2015 | 09:24 AM
tjc transport
i ain't rite
if the parts truck is a dual wheel pickup, the only difference is the axle to axle flange width to allow for the dual wheels. on a dually i believe it is 3 inches wider if i remember correctly. the axle will bolt rite in, you will just need to trim the fenders to keep the outer wheels from rubbing.
Old Aug 15, 2015 | 09:49 AM
Diesel_Brad's Avatar
Diesel_Brad
Dually PICKUP rear axles are 6" wider than SRW
The cab-n-chassis dually axle with is almost the same as a SRW axle
Pickup frames are the same width SRW or DRW.
Cab-n-chassis frames are narrower
All you need to make your SRW truck to DRW is.....
-Dually pickup rear axle from a 2wd/or conversion adapters
-Dually Pickup bed from a 2wd/or conversion fenders to go on your SRW bed
-Dually front hubs to go on your axle in place of the SRW hubs/or conversion adapters
-6 dually wheels/ with the correct lug nuts
have a read. I converted my truck a couple of years ago
https://www.ford-trucks.com/forums/1...csb-build.html
Old Aug 15, 2015 | 04:22 PM
Vertrees's Avatar
Vertrees
I have to hand it to you Brad, that is an impressive job and write up
I will most certainly be giving that article another read through to make sure I did not miss anything!
Old Aug 15, 2015 | 07:08 PM
mechmagcn's Avatar
mechmagcn
Just my luck as the dually is 4:10 and the F250 has 3:55s in it. Guess it'll be time to look for a Dana 60 for the front.
Is it even possible to convert the D50 TTB to dually hubs?
Old Aug 15, 2015 | 07:13 PM
mechmagcn's Avatar
mechmagcn
I see lots of late models around here, but no OBS trucks. A friend tried to order a F350 DRW 4X4 in '97 and was told the only way to get 4X4 in a dually was cab and chassis.
Old Aug 15, 2015 | 07:20 PM
427 fordman
Yep, that's what I did. No different than converting a 60. Just bolt the dually hubs on.
Old Aug 15, 2015 | 07:33 PM
mechmagcn's Avatar
mechmagcn
Is it just an adapter or the entire hub assy?
Old Aug 15, 2015 | 07:35 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
the D50 and D60 use same hubs.
here are arrowcraft aa4 front dually wheel adapters i used to convert the front of my f250/d50;
