Sponsored by: Real Truck
7.3 Flat spot
Old Aug 14, 2015 | 09:08 PM
Brownie12's Avatar
Brownie12
Question 7.3 Flat spot
Hi There
2003 7.3 Sd Has a flat spot from 2700 - 3000rpm especially when it changes down , say going up a hill , if I decelerate and let it change back up it will pull again but if I leave it changed down it will not rev anymore. No CEL , put it on the scanner , only code that came up is " intake temp Low " which would not effect it. Have just installed new up pipes , new HPOP hoses , in the past it has had a new IPR and HPOP . It had this flat spot before and it would bring up low boost pres hence the up pipes . Have checked all flanges and intercooler boots etc . All help would be appreciated down here in New Zealand
Brownie
Old Aug 22, 2015 | 10:06 PM
Brownie12's Avatar
Brownie12
Thumbs up Sorted flat spot
Hi all , as nobody replied I thought I would post what I found .
Stripped it back down again checked all intercooler boots etc again = no problems. Finally found a hair line crack in the O ring on the cold outlet of the turbo , had to use a magnifying glass to find . Fitted a new O ring and " Holy " did it make a difference = heaps of power like I have never had before One happy chappy
Old Aug 22, 2015 | 10:38 PM
NYCruiser's Avatar
NYCruiser
Glad you got it sorted. Was gonna say to check for boost pressure carefully. Amazing what a dog they can become if they lose boost.
Brownie12
General Diesel Discussion
Aug 17, 2015 10:26 PM
patnode22
Oct 31, 2014 04:49 PM
part time wheeler
Dec 27, 2013 10:10 AM
frdf250
30
Oct 9, 2009 12:43 AM
nicebenz68
Competition
Aug 18, 2008 12:46 PM
