Sponsored by: Real Truck
Rear Stabizer Bar
Old Aug 13, 2015 | 12:33 PM
afhanson72's Avatar
afhanson72
Rear Stabizer Bar
I bought a 2011 F350 CC SRW 4X4 Lariat. It is not the FX4 package. I noticed other similar trucks running around with a rear stabilizer bar. Mine does not have one. Was this an option when the truck was new? If so, does it really help at all? Can I add it to the truck?
Thanks for any input!
Old Aug 13, 2015 | 03:13 PM
donovan's Avatar
donovan
Old Aug 13, 2015 | 03:28 PM
afhanson72's Avatar
afhanson72
Thanks! Sure looks much beefier than the stock ones I see!
Old Aug 13, 2015 | 03:31 PM
Chuck's First Ford's Avatar
Chuck's First Ford
I have the Base model 2012 F 250... 6.2L.. with towing package and it HAS the rear anti-sway bar... oh... Rear Wheel Drive ...only.
Old Aug 13, 2015 | 04:19 PM
donovan's Avatar
donovan
Hellwig
That should work on both 4x4 and 4x2. The back of the truck is the same for 2 wheel and 4 wheel drive.
Old Aug 13, 2015 | 07:37 PM
LariatRick's Avatar
LariatRick
The towing package adds the Ford rear sway bar. Mine didn't have one so I got the Hellwig Big Wig. It's a must have to haul a truck camper. Made a big difference! Love it! Easy to install too. And much beefier than Fords. $250 on amazon.
Rick
Old Aug 13, 2015 | 07:57 PM
NYCruiser's Avatar
NYCruiser
Its the camper package that adds the rear sway bar I think.
Old Aug 13, 2015 | 09:38 PM
Omega Man's Avatar
Omega Man
I'm contemplating removing mine, rear springs are so stiff, I'd like to improve my ride quality.
Old Aug 14, 2015 | 04:53 AM
Chuck's First Ford
anti-sway bars do not make the ride stiffer.... just reduces the sway.
Yes, I forgot.. mine has tow package and camper package..
stiffness is Springs and to a lesser degree Shocks.
Old Aug 14, 2015 | 08:09 AM
LariatRick's Avatar
LariatRick
You're right, camper package not towing package. But the Hellwig is much bigger!
Old Aug 14, 2015 | 10:28 AM
donovan's Avatar
donovan
Bounce is caused by the springs and to a lesser degree shocks. The easy fix is sand bags behind the rear axle. My trucks rides great with 500 pounds in the bed.
I replaced my shocks and it helped but weight is what is needed in the bed.
Super Duties trucks are real trucks and the ride is not the same as a car.
Old Aug 14, 2015 | 12:45 PM
Omega Man's Avatar
Omega Man
I didnt say it makes the springs stiffer. I said my rear springs are very stiff. Implying that for me personally the sway bar isn't necessary. I want each side of my rear end to cycle independent of the other, which should make for a minute improvement in in ride quality.
Old Aug 14, 2015 | 12:49 PM
Omega Man's Avatar
Omega Man
Shocks are next on my list, I will be investing in some Bilsteins, just need to figure out the correct valving I require. I know my passenger side front is practically dead, it has very little dampening effect compared to the opposite side.
0351mike
1978 - 1996 Big Bronco
May 8, 2018 04:20 PM
caprang
May 20, 2008 11:07 PM
4.9inline6
Jul 14, 2006 10:33 AM
wolffee
Sep 15, 2004 02:59 PM
narcicus
Jul 18, 2003 02:50 PM
