no start, just click.
Old Aug 12, 2015 | 09:52 PM
96inline's Avatar
96inline
so i have a 351 I got in a junkyard that i'm swapping in. got everything hooked up and when i try to start it I get a click. I tested the starter and it seemed to work(gear moved up and started spinning). When I first tried I heard a grinding noise but the engine was moving(slowly). Before that I was able to crank the engine with a breaker. I then realized I had to oil the cylinders so I pulled the plugs and squirted some marvels mystery oil in. I can crank it smoothly with a breaker bar with a little grunt(no rough spots) . Now when I try to start it, it just clicks. 2 different batteries both with time to charge overnight. Any suggestions welcome, could it be the relay, solenoid, any way to test? Feel free to ask for clarification.
Old Aug 13, 2015 | 12:04 AM
Willz74's Avatar
Willz74
It'll spark a bit but if you use jumper cables on both sides of the relay it'll try to start it's called jumpering do it with the key in the on position to make it start off to just crank
Old Aug 13, 2015 | 12:17 AM
88XLTLariat's Avatar
88XLTLariat
I agree with Willz. I'd look at the relay first. Should be on the passenger side firewall.
Old Aug 13, 2015 | 12:25 AM
96inline's Avatar
96inline
what if it still clicks then?
Old Aug 13, 2015 | 12:30 AM
88XLTLariat
Battery cables and grounds would be next on my list.
desertshark
Jun 6, 2017 09:57 PM
bheneee
1997 - 2003 F150
Jun 17, 2012 12:47 AM
Idiomaticman
Apr 27, 2010 06:57 PM
sandmann
Aug 25, 2009 12:16 AM
tbonelynch
1983 - 2012 Ranger & B-Series
Jul 14, 2006 07:21 PM
