302 engine
Old 08-12-2015, 12:37 PM
Bearhead's Avatar
Bearhead
Bearhead is offline
302 engine
Will any 302 engine line up with a manual trans for a 79 f150 ranger. 2wd? I'm sure there is a link but I'm not finding an exact answer I'm looking for
Old 08-12-2015, 12:46 PM
Canus's Avatar
Canus
Canus is offline
Not enough info. Later blocks will not have the boss on the drivers side that the "Z" bar connects to. Other than that any 302 should work.
Old 08-12-2015, 12:59 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Not enough info... which manual trans/bell???
Old 08-12-2015, 01:04 PM
jas88's Avatar
jas88
jas88 is offline
I am going to assume the trans for the '79 is for a 302? I must be, or for a 300, the 351M/400/460 trans will not work.
Old 08-12-2015, 01:10 PM
Shakes the Rat's Avatar
Shakes the Rat
Shakes the Rat is offline
If the 3 speed was from an inline 6 or 302 equipped truck (small block bolt pattern) then yes, it will physically bolt up. As was said before, there is the issue with z-bar, but there is a company that sells a bracket that bolts to the back is the bellhouse. It's a simple bracket to make if you have a welder. If you use a late model 302, you have to use the proper balancer (50 ounce imbalance) and flywheel since the early engines used a 28 ounce imbalance.
What is in the truck now?
Old 08-12-2015, 04:51 PM
Bearhead's Avatar
Bearhead
Bearhead is offline
not sure on what trans it it, its a 4 speed with a granny low. Im new to 79 world
Old 08-12-2015, 05:08 PM
Bearhead's Avatar
Bearhead
Bearhead is offline
i'm looking to pull my 302 out, and either rebuild or replace, just wondering bout maybe taking a mustang engine and sticking it in there
derk001
19
03-21-2019 06:02 PM
moparman19
04-27-2011 11:10 PM
LEADSLED52
03-19-2011 10:15 AM
desperado_18_2000
06-29-2002 11:22 PM
Quick Reply: 302 engine
