6v gauges to 12v?
Piece of cake with a resistor ballast. http://www.summitracing.com/parts/ms...FY89gQodOVUMiQ
Here is a quote from Speedway regarding use of the ceramic reducers..
Note: Never, ever use ceramic block style reducers for gauges, radios or lighting. A power surge will destroy the electronics when first turned on. Ceramic block reducers should only be used to operate 6 volt DC motors and fans on 12 volt DC.
1948-55 Ford F-100 Voltage Reducer, Electronic, Gauges 1.5 A
I agree the L7806 is a good way to reduce 12V to 6V.
My question is: since the polarity of 12V is negative ground and the polarity of 6V is positive ground, should the terminals on the gauges need to be wired reversed (power input and sender wires reversed) because the power goes the opposite direction?
Thanks,...jack
Thanks,...jack
