Steering connection problems
Old Aug 11, 2015 | 05:31 PM
Chad McClain's Avatar
Chad McClain
I have a 66 f100 I just bought and a week later I see this
I'm a little confused about what I can do besides getting a new rag joint?
Old Aug 11, 2015 | 07:05 PM
daveengelson's Avatar
daveengelson
First and Foremost, Welcome to FTE!!! Difficult for me to determine from pic's, if I were to hazard a quest, appears to me PO either installed the incorrect coupler (rag joint) and/or installed incorrectly?? Suggest try replacing the steering coupler (rag joint, should not run for than $20-30 and regardless will need to be replaced??
Sorry, pic's pathetic, but decided to post pic's of the coupler from my 65, which has the P/S upgrade, but would be same as the manual with respect to rag joint between steering box and steering shaft. Suggest wait for other member's to chime in for additional comments. Again, welcome and looking forward to your input!.
Old Aug 12, 2015 | 04:48 AM
jowilker's Avatar
jowilker
Chad Welcome to and The Slicks Forum.
Looks like it's time for a new rag joint with the left side bolt short like the right side. Not sure if the bolt has caused the oil leak but the steering gear may have to be re-sealed.
John
Old Aug 12, 2015 | 11:35 AM
daveengelson
If can afford, since replacing the rag joint will likely require loosening the steering column, noticed in pic the lower steering column bearing seal appears to be unseated so you may want to take the opportunity to purchase the components to repair the column and include 2-3 items required to restore the horn, probly cost total of approx. 30-$40?? If parts are ordered in advance likely take a weekend?? Anyhow, food for thought.
Old Aug 12, 2015 | 02:31 PM
Crop Duster's Avatar
Crop Duster
Take a good look at the cab mounts also. If they are starting to fail and letting the cab settle down it will put the steering column rag joint in a bind.
JNye
Jan 24, 2019 04:03 AM
LACzar
Sep 28, 2017 01:52 PM
Elcid
Apr 20, 2016 11:41 PM
Frankie33
Feb 6, 2013 01:58 AM
chadwickma
Nov 9, 2006 09:40 AM
