1978 - 1996 Big Bronco
v 10
Old Aug 10, 2015 | 08:10 PM
johnjg's Avatar
johnjg
v 10
i have a 90 bronco 302 5 sp trans ,i would like to install the 1999 v 10 motor and auto trans. with the axles. i have the complete truck f350. the axles are in the bronco. any help with the engine and auto trans.
thanks john
Old Aug 11, 2015 | 01:02 AM
g_k50's Avatar
g_k50
I'll take the old engine and trans set up.
There's nothing like a good original Bronco.
What's the attraction to the V10?
Old Aug 11, 2015 | 08:17 AM
bigzirb's Avatar
bigzirb
Good luck. I would think swapping the entire wiring harness would make for the least number of electric gremlins to contend with. I have a V10 Excursion so I know you will like it. Keep us posted on your progress.
Old Aug 11, 2015 | 07:01 PM
gatorfor88's Avatar
gatorfor88
Good luck getting a mod motor v-10 to fit in a Bronco engine bay.
Old Aug 12, 2015 | 11:16 AM
Kemicalburns's Avatar
Kemicalburns
If you can pull the body off the bronco I would recommend it as this will give you the best access for fitting that motor between the rails.
Old Aug 12, 2015 | 04:38 PM
johnjg's Avatar
johnjg
sorry the 302 & trans are gone, i just put the body back on the frame after paint.
i will check to see if the v 10 will fit or maybe a 460 or bigger
Old Aug 12, 2015 | 09:40 PM
Encho's Avatar
Encho
The Southernmost Mod
You really need to think about the reason why you want this, it's a rather expensive modification.
banshee rider81
Ford Truck Parts for Sale
Mar 8, 2014 03:32 PM
captain p4
Modular V10 (6.8l)
17
Sep 1, 2008 09:58 PM
GLR
Modular V10 (6.8l)
Jul 11, 2008 01:20 AM
mrknight01
27
Oct 14, 2007 06:03 PM
skelator84
Sep 26, 2005 02:24 PM
