Last Thur I hung an engine on my 1957 Massey Ferguson tractor - I was amazed, I used an engine hoist and a chain - I pumped up the hoist and eyeballed the alignment and pushed it in, bumped into something that was too far away from where I needed to be - Went and looked things over, The bell housing is part of the tractor and it doesn't have any inspection holes - I swagged the alignment, bumped the hoist a n'th and pushed it back in - I bumped up against something again - I grabbed the engine, huffed and puffed and wiggled it a bit and it slid all the way home - I looked around and there wasn't a darn sole around - I bolted the engine on and moved on to another project that popped up - I tried engaging the clutch and I had nothing - I could turn the engine over with a big ratchet on the pulley, I went back and played with the clutch and I remembered that I had takened the bolts out of the cross shaft - I pulled the engine out and reinstalled the cross shaft bolts - I put a jack under the engine hanging on the hoist and called it a night
Yesterday morning I went out and got the tools ready removed the jack and pushed the engine in - I hit the whatever at the same place as I did before - I wiggled the hoist, then the engine, pulled the hoist back, checked the alignment, measured every the height - Said a Voo-Doo chant and pushed the engine back in - From noon yesterday until noon today I spent 6 hrs wiggling, jiggling, cussin and fussin and got no where
I took a 2 hr break got some lunch and fussed myself into a tizzy
I went back to the garage and dug my lift table out - I marked the center, set some blocks and jacked it up under the engine - I took the hoist off and went to work eyeballing everything and pushed it forward - Hit the same damn thing - I got out my long screwdrivers, cheater bars and slid them thru the bolt holes - Ta Da everything lined up, hut the level on, on the money - I worked until 5 went in and fixed supper about 7 I went back out and same old, same old - I got a paint stick out and painted the nose of the trans input shaft - It was marking the top of the clutch shaft - I tried to lower the table but I couldn't control the amount of movement - Played around and got it back to where it was marking as before - I cut some 2x4s and made some wedges - I started at the front and tapped the wedges - All the time I was making the adjustments I was turning the crank and putting pressure on - Same, same - I went and had a ciggie - I pushed on the table and it slid in about two inches - That had to be the splines engaging - I pushed and bumped and couldn't make any progress - I got out some big C-Clamps and clamped where I could so I would loose any thing - Wedges, pry bars, and blue smoke got the engine close enough that I could start some bolts - Tighten a bolt adjust a c-clamp, again and again - I leaned over the table to get a bar and as I did that I leaned on the fan snout and the engine slid right in - It was aligned so good that I could finger tighten almost every bolt - When I got them all tightened I put away my tools, turned out the lights and locked the doors
I had a snack , a smoke, played with the dog and came back to the puter and wrote this lament
So there I was trudging across the trunda, mile after mile --------------
Dave the MF 135 is not that much different - I have the front loader and the main brace for that is mounted right behind the break, two jack stands and all was secure - the front sheet metal is taken off including the dash/battery case, next the gas tank, then the radiator - The last little bit is the front axle assembly - I took the control arms off at the back so that I wasn't tripping over them - Moving them anywhere was like moving a sow in heat and a boar with a yard stick between them
You Sir have been gifted with a bushel and a half of perseverance, and that is undeniable. Im not the best reader but I was so engrossed in your story that I read it four times. Congratulations on a job well done.
