63' Rear Leaf Spring Count
Old Aug 9, 2015 | 08:51 PM
Wolfracing's Avatar
Wolfracing
I have a 63 step side f100 with the little 6 and three on tree.
I snapped off a lower rear shock mount.(the stud itself) Where can I get a replacement and are these simply a shoulder bolt? If I can get the stud, I have no issue with drilling out and welding back in.Edit: Figured out
Now for the big picture: This one has always sat high in the rear. I'm not sure how many leafs should be in the rear. I am thinking if a reduce to 5, I can lower it a bit and have it sit more or less level. But I have never done this, so I don't know what removing 3 leaves will do. Will this make it ride considerably rougher? Any need for angle shims at this level of lowering? What pinion angle should I be shooting for? Still need help with this part!
Thank you!
Last edited by Wolfracing; Aug 10, 2015 at 02:41 PM. Reason: No responses yet, and fixed one problem already
Old Aug 10, 2015 | 05:58 AM
Wolfracing's Avatar
Wolfracing
All these views and no replies. This is a occasional driver and a rough one at that. I'm just trying to get it a little more usable and reliable. Certainly some of you have run into this stuff.
Old Aug 10, 2015 | 08:43 PM
fivestarmmd's Avatar
fivestarmmd
I have 2 64 short beds with 5 leaves. 1 uni short with 8,1 uni short with several added. 1 63 reg long with 10 but added 3 years ago
Old Aug 10, 2015 | 09:24 PM
Wolfracing's Avatar
Wolfracing
Well that's quite a range! I will try 5 and see what it does for now.
Old Aug 13, 2015 | 03:31 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
'63 Rear Leaf Spring Count
1957/67 F100 2WD rear springs interchange / 2 1/4" wide / 24" > eyebolt < 28"
1963 F100 2WD: 8 leaf spring pack with 1025 lbs. load rate / 8 leaf spring pack with 1700 lbs. load rate / 9 leaf spring pack with 1650 lbs. load rate.
1964 F100 2WD: 5 leaf spring pack with 950 lbs. load rate / 6 leaf spring pack with 1650 lbs. load rate.
1965/67 F100 2WD: 5 leaf spring pack with 950 lbs. load rate / 6 leaf spring pack with 1250 lbs. load rate / 9 leaf spring pack with 1650 lbs. load rate.
Old Aug 14, 2015 | 10:17 AM
Wolfracing's Avatar
Wolfracing
It's curious why this sat with such a rake. I don't mind some extra height in the back, but this one is kind of extreme. It's possible it is sitting lower in the front due to age, making it seem worse. We never load this thing at all. We will see what the 5 does, and if it is a disaster.
Thank you!
fatfords
Feb 8, 2023 07:56 PM
littsen1
13
Oct 31, 2013 10:36 AM
rickdog67
Jan 31, 2004 09:38 AM
skater2570271
Oct 29, 2003 12:48 PM
JIM ROBINSON
Oct 23, 1999 09:26 AM
