SOMEONE HELP!!!!!!
Old Oct 18, 1999 | 04:38 PM
JIM ROBINSON
Guest
Posts: n/a
SOMEONE HELP!!!!!!
IM IN THE PROCESS OF BUILDING A 71 F-100,IT HAS A 302 AUTO. THE FRONT END WILL BE LOWERED 3in..THE PROBLAM I AM HAVING IS WITH THE REAR,THE TRUCK HAS WHAT FORD CALLED FLEX-O-MATIC SPRINGS.....DOES ANYONE KNOW HOW TO LOWER THE REAR WITHOUT CUTTING THE WHOLE THING APART???? PLEASE LET ME KNOW. wallace2@gibsoncounty.net
Old Oct 21, 1999 | 10:23 PM
mark rogers
Guest
Posts: n/a
SOMEONE HELP!!!!!!
I just lowered my 68. Used lowered shackles and hangers. Bolted on real nice. Can't speak for your current situation, but if you round up the shackles and hangers and put (probably) different springs on you should be in shape!
FYI- it supposed to lowere 4" on rear to make the truck level with the 3" lowered on front.
Old Oct 22, 1999 | 01:46 PM
Bill's Avatar
Bill
SOMEONE HELP!!!!!!
Might try contacting Carolina Classics ((919) 682-4211) and ask about the mono leaf rear spring set up.. cost about $400 bucks but you can lower the rear anywhere from 2.5 to 5 inches depending on which spring you order.. I have talked to them about my '64 and this set up...
Old Oct 23, 1999 | 09:26 AM
Duane Burgess
Guest
Posts: n/a
SOMEONE HELP!!!!!!
WachusettF150
Jun 14, 2010 05:34 PM
tonydlt
Feb 19, 2007 11:39 AM
flyboy2610
Feb 6, 2002 07:54 PM
ogre316
Oct 23, 2001 04:39 PM
