Lost power then died
Old Aug 9, 2015 | 05:00 PM
kbbagshaw's Avatar
kbbagshaw
My 2006 F250 was towing my 5th wheel when it started to loose power and eventually died. Would not restart. Replaced all fuel filters to no avail. Towed to mechanic shop. Has a little over 100,000 miles on it. Waiting for mechanic to check it out. Ideas?
Old Aug 9, 2015 | 05:26 PM
npccpartsman's Avatar
npccpartsman
STC fitting at HPOP if it hasn't already been done. The HPOP itself on this year truck is VERY reliable.
Check fuel pressure and FICM voltage.
Anything is a guess at this point but these are the most common issues of lose power and die.
Old Aug 10, 2015 | 09:02 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Don't rule out the dummy plugs either, when they completely fail, the truck will exhibit a crank no start condition.
Slightly time consuming, but easy fix if it is the dummy plugs.
Old Aug 16, 2015 | 09:41 PM
kbbagshaw's Avatar
kbbagshaw
STC fitting at HPOP
Looks like it is the STC fitting at HPOP as advised, thanks for the suggestions.
kalsc
Jul 18, 2019 06:07 PM
wfof250v10
Modular V10 (6.8l)
Jun 26, 2014 06:19 AM
Super Duty Mike
Mar 23, 2012 07:35 PM
ware8083
1997 - 2003 F150
Oct 4, 2009 07:54 PM
OSin86
Bronco II
25
May 6, 2006 08:44 AM
