351w timing issue? maybe?
Old Aug 8, 2015 | 05:56 PM
caleballen95's Avatar
caleballen95
Fellas, I have a 79 f-150 and somewhere along the line someone put a 351 Windsor with a Holley 4bbl carburetor , the engine starts and runs idles fine. However when you rev it up it shakes something awful. Similarly I put it in reverse/drive to move it the other day and whenever I gave it some gas it would shake pretty bad and then almost cut out and it actually died a few times.. could this be an air fuel ratio issue? Timing? Thanks in advance!
Old Aug 8, 2015 | 07:50 PM
Canus's Avatar
Canus
Are you sure the firing order is correct. The correct order for a 351W is 1-3-7-2-6-5-4-8. The firing order for a 302 is 1-5-4-2-6-3-7-8. If your engine is set up with a firing order for a 302 the engine it will will crank and run but not to its optimum. You could also have a timing or carburation issue.
Old Aug 9, 2015 | 11:14 AM
redroad's Avatar
redroad
Since the 351W never came in the truck how the motor perches and motor mounts are installed is where I would look first .. For example if the previous owner cobbled something together using motor perches that weren't intended for that motor it could have broken a motor mount .. or maybe there is missing motor mounting hardware .. Do we know if this motor transmission combo was ever run successfully in this truck prior to you getting it ?
Old Aug 9, 2015 | 02:47 PM
bkaul's Avatar
bkaul
True ... though why someone would cobble something when the mounts are identical for the 302 which *did* come in these trucks would be a bit of a mystery if that ends up being it ...
Can you describe a little more what happens when it "shakes"? Is it misfiring or does it seem to be unbalanced at higher engine speeds when you rev it? In the latter case, it could be that someone installed the balancer for a late-model 302 that has a 50-oz imbalance instead of a 28-oz imbalance, etc. If the former, then look to mixture or ignition.
Old Aug 9, 2015 | 04:21 PM
lewistg's Avatar
lewistg
when I pulled my 460 for rebuild I had motor mount bolts missing.
firemenjay
1966 - 1977 Early Broncos
Mar 9, 2011 09:49 AM
TheJunkMan
Jan 18, 2011 08:48 PM
me123
Mar 7, 2006 06:45 PM
jmac
May 19, 2002 02:34 PM
George
1978 - 1996 Big Bronco
Aug 18, 1999 10:55 PM
