I hate to see a simple question like this get ignored.
You will either have a 1-3... or a 1-5... firing order. Most likely, with it being a 351,it will have a 1-3... order, but someone could have put a 302 cam in it and it may have a 1-5...
The easiest way to check is to pull the 1, 3, and 5 plugs and put your thumb over them as you turn the motor over (get a freind to help). If the 5 blows first after number one then it is the 1-5 order. Otherwise it is the standard 351 order.
Thats your firing order. Drop the distributor in with #1 at TDC and rotor pointing to #1. Leave just loose enough to turn distributor with a "little" effort. Somewhere around 8-10 degrees BTDC and it'll fire up. Fine tuning comes after breaking in the cam.
1-3-7-2-6-5-4-8 = 351 or 302 HO
1-5-4-2-6-3-7-8 = 302
That fish (ur avatar) looks like it'll eat me. I say it's a point of eat or be eaten!
All winter I learned to tie flys (bout 16 kinds, 1st try @ it) & can't wait to test em out.
