Got a weird one here folks
Sort of a round about PCM test step.
Are you getting any ICP and IPR readings and what are they?
When it's trying to start have you looked at unplugging the ICP
to see if that will let it start?
Sean
6.0L Tech Folder
Sean
6.0L Tech Folder
of a truck that was running.
Sean
6.0L Tech Folder
Hi Guys, thanks for the responses. Its a new ficm from diesel tech ron, and he programmed it for an 04. Ipr off is at 14.4 and goes up as im cranking, icp 1100+. I did try unplugging the icp n no luck. Ive read thru just about every no start thread on here so i checked everything i could before buggin u guys.
Appreciate the help
shem
Appreciate the help
shem
on
New doen not equal a good part.
Ohm out each injector through the injector harness at the ficm connections. If there all under 5 ohms then in theory the injectors and harness are good. That leaves 2 options you failed to make a correct connection or the new ficm is in fact bad.
If my Monday your still scratching you head on this one give the guys at
FICMRepair.com - FORD Powerstroke 6.0 FICM Repair, PHP Tuning and Truck Parts
a call. I herar that Ed took a real vacation and will be back Tuesday.
But some of the skilled people will be there one of them can help you out.
BUT let them know where you got it. If they get you going then you may
want to give them a little something something for the time. You do know that
Ed has a test bed that they check the units on before they leave. Also be sure
to check for bent pins or pushed out pin sockets.
Sean
6.0L Tech Folder
Sean
6.0L Tech Folder
U guys are awesome! i will check for shorts in the morning, thanks for the diagrams! i will dig into the glow plugs too. i did unplug the gpcm and try to start with no luck. Saw that in another thread, tried disconnecting the ebp too. Boy have I learned a lot about my truck. U guys rock!
shem
shem
#30
Unplugging things is an easy way to troubleshoot sensors or some electrical glitches, but it creates problems when you are using codes to track down problems. Be sure to write down your troubleshooting information (and in chronological order). That way GP codes (that weren't there originally) don't throw you off track when you get them later (after trying to start w/ the gpcm unplugged).
