As in a previous post, i have been having issues with my truck starting then immediately dieing if i dont keep my foot on the gas.
Ive learned how to drive with 2 feet because of it, but I'm afraid i might be doing some type of damage since it keeps dieing and I have to keep starting it.
Once i get going for about 10-15 minutes its fine but its happening every time i start the truck.
Before it starts running correctly, it only idles around 400 rpm.
I think its the fuel pump, since my mechanic put a code scanner on there and it didn't throw any codes, he thinks it might be the fuel pump.
My question is, should i go with a ford pump from the dealer or are the ones sold from discount/o'reilly/napa just as good?
when replacing the iac, do i need to remove the air intake and should i be concerned about the bottom tube that run from the intake to the engine breaking or not flexing?
I dont want to take things apart and have that tube come off the engine or snap.
Just take your time and it'll come off easily enough. I recall cleaning the general area first with a rag. Heck while you're in the neighborhood, clean your MAF too.
