I have a small coolant leak coming from the passenger side near the back of the engine that forms a spot about the size of a dinner plate if it sits for a few days.
One thing I noticed is if I turn off the AC selector switch when I park I will get the drip but if I leave the switch on MAX AC when I shut the truck off I do not get any leaking.
It is definitely coolant and not just the condensation from use of the AC.
If I haven't used the truck for a few days or if I have run it with the AC off I will get the drips.
If I run with the AC on and leave the switch in the on position when I shut the truck off it won't leak.
I have tried to locate it from looking above and below but can't determine where it is coming from.
Sounds like a leak in the heater core return to the degas resevoir. Check the Y connection and hose under the degas and the hose where it connects on the firewall cross over pipe (near the FICM).
Oops edit. I thought I read driver side.
For passenger side check the heater core control valve. They are prone to leak. It has the grey vacuum line going to it.
