Hpo problem
Old Aug 5, 2015 | 02:24 PM
SHANN0N's Avatar
SHANN0N
Hpo problem
Hello all hope your day is good
Anyway I have a no start problem and I'm pretty shure it has to do with the hpo system I when I turn it over it has no pressure on the oil gage for about 10 to 15 seconds of crank time then it comes up to ware it should be but it still won't start and if I quit cranking for a second and try again I have to wait for that time again to get pressure. So I'm thinking that one of the tube must be cracked and is not allowing the pressure to bid to the 500 that it needs what do you guys think.
O sorry guys it's an 04 f250 extended cab 4" straight pipe, air raid intake, arp studs, egr delete, 212,000 miles, edge tuner, replaced the oil cooler rebilt the turbo about 8 grand ago that's about it
Old Aug 5, 2015 | 02:57 PM
mustang_309's Avatar
mustang_309
What are your ICPV's at KOEO?
Have you tried unplugging the ICP sensor then trying to start it?
What is the FICM voltage at KOEO and while cranking?
KOEO=Key On Engine Off
Old Aug 5, 2015 | 03:06 PM
SHANN0N's Avatar
SHANN0N
I'm not sure I ordered a obd2 that should be in Thursday or Friday.
Also can you help me out with all the abrevation's I am not sure what they all mean thanks
Old Aug 5, 2015 | 04:08 PM
mustang_309
ICPV= Injection control pressure volts
FICM= Fuel injection control module
Old Aug 5, 2015 | 07:09 PM
SHANN0N's Avatar
SHANN0N
Thank you I'm hoping to have my scanner bye Friday we will see when it gets here
RobMF250
Jul 20, 2018 08:20 AM
EricdeToad
Feb 24, 2015 09:27 PM
Corky08
Sep 25, 2013 10:21 PM
04miaf250
Jun 29, 2013 11:00 AM
HunerdProof1371
Dec 28, 2012 03:48 PM
