Fuel gauge
Old Aug 5, 2015 | 07:55 AM
Diesel_Brad's Avatar
Diesel_Brad
Fuel gauge
Looking to install fuel pressure gauge. How can I tie into my fuel rail?
Ps this is a permanent gauge so I need to mount a sending unit
Old Aug 5, 2015 | 10:26 AM
Freightrain's Avatar
Freightrain
My buddy who races a foxbody still runs FI and has a gauge on the cowl. I guess you need the adapter to screw into the schrader valve for 1/8" pipe fitting.
Something like this:
http://www.summitracing.com/parts/atm-3280
or better yet:
http://www.shop.speedunlimited.com/p...e-fitting.aspx
Old Aug 5, 2015 | 01:29 PM
rla2005's Avatar
rla2005
X2...put the fuel pressure sender on the fuel rail test port.
Old Aug 5, 2015 | 02:44 PM
Diesel_Brad
Thanks for the links. I'll have to look at them better when I get home. Pretty sure my sending unit is 3/8
Old Aug 5, 2015 | 02:52 PM
Freightrain
3/8" npt? Wow, that seems pretty large. What brand?
I've seen some that come with an adapter for the 1/8" male to go up to 3/8" to fit larger holes.
Here is one from Autometer that is 1/8" npt.
Auto Meter 2229, Auto Meter Replacement Senders & Sensors | Auto Meter
Old Aug 5, 2015 | 04:57 PM
Diesel_Brad
AEM
Fuel Pressure Display Gauges | AEM
Old Aug 6, 2015 | 07:49 AM
Diesel_Brad
My bad, it is 1/8"
Does anyone know where to get the -4an(female) to 1/8" pipe(female) adapter?
Old Aug 6, 2015 | 09:32 AM
subford's Avatar
subford
You might want to look at this link:
http://www.stealth316.com/2-fuelsupline.htm
Old Aug 6, 2015 | 09:58 AM
Diesel_Brad
Thanks. But I have FMU that regulates fuel pressure with a secondary fuel pump so I don't think I need and adjustable regulator
Old Aug 6, 2015 | 10:23 AM
subford's Avatar
subford
The link was to show ways to mount the gauge sender and would apply to all fuel injector fuel systems.
Old Aug 6, 2015 | 10:44 AM
Diesel_Brad
WAY involved. to not use an $14 adapter
Old Aug 6, 2015 | 12:19 PM
Diesel_Brad
Has anyone ever removed the schrader valve from the fuel line?
The automata adapter 3280 shows it is 1/6" NPT to 1/8" NPT but the Schrader valve has no hex to grab with a wrench. I don't want to go twisting it off with a pair of Vise grips if it is not designed to be removed and brake the fuel rail
Old Aug 6, 2015 | 01:23 PM
GoinBoarding's Avatar
GoinBoarding
My grandfathers was leaking, I replaced the whole valve. That was an 02' 4.6L. Just checked my 96' 5.8L and the whole valve is removable too. BUT both of those had a hex for a wrench on the valve, and I can clearly see the connection is threaded on my 96'.
What truck is this on? EDIT, just saw the other thread, 96' 460.
Old Aug 6, 2015 | 02:32 PM
subford's Avatar
subford
It is not removable on the 460 engine. At least on my 94 F53 and others have found out the same thing on other 1990's F53's.
I would think the F-series trucks are the same way.
Old Aug 6, 2015 | 06:34 PM
eakermeld's Avatar
eakermeld
It is removable on my 89 460
