Sponsored by: Real Truck
Electronic Brake Contoller
Old Aug 1, 2003 | 08:07 AM
Strokin 6.0's Avatar
Strokin 6.0
AnyOne installed the electronic brake controller in an F-250 superduty? It appears to be a simple task, but I am a little apprehensive.
Old Aug 1, 2003 | 08:15 AM
f350xlt460's Avatar
f350xlt460
I would imagine that its very simple on your truck as it was a piece of cake for me. Just go to a camping/trailer store and get the plug adapter. Solider (sp?) the wires to the adapter plug and then plug it in. Be sure to spend the time to level the controler as the instructions say.
Old Aug 1, 2003 | 11:38 AM
nafzimo's Avatar
nafzimo
Take the panel off under the dash and there is a plug taped to the back of the dash support on the right side. There should be a matching "pig tail" in the glove box. Wire the pig tail to your new Prodigy controller and stick the mounting braket to the underside of the dash (below your cubby hole) with 3M double sided automotive tape. Done. No leveling needed with the Prodigy.
Old Aug 2, 2003 | 03:46 PM
shorebird's Avatar
shorebird
Prodigy makes an adapter that plugs straight into your truck and into the controller. There should be no need to splice any wiring.
Old Aug 2, 2003 | 09:16 PM
nafzimo's Avatar
nafzimo
If you have the "pig tail" that came with the truck, there is no need to buy the "adapter that plugs straight into your truck". It is a four wire nut job from there. Hardly worth the extra $13 harness.
