Sponsored by: Auxito
2003 5.4 Engine Stutter While Turning
Old Aug 4, 2015 | 04:01 PM
miked79928's Avatar
miked79928
My 2003 f150 5.4l has developed a slight stutter when I turn from a stop or go from reverse to drive or vise versa. I had thought it was the IAC so I replaced it but the issue is still there. There are no engine codes and it does not miss fire at idle or while driving. The problem appears to be happening only when the a/c is on. Could the belt be the cause? Has anyone ever experienced this before? Thanks in advance!
Old Aug 4, 2015 | 07:14 PM
auskip07's Avatar
auskip07
https://www.ford-trucks.com/forums/1...ing-space.html
Old Oct 5, 2015 | 07:30 PM
miked79928's Avatar
miked79928
Ok. I have replaced the iac valve and checked all vacuum lines. I am getting ready to replace the coils. My question is should I be looking at?
Old Oct 8, 2015 | 02:47 PM
miked79928's Avatar
miked79928
Just to add, this issue only occurs once the truck has reached operating temperature.
Old Oct 9, 2015 | 06:16 AM
enriched&beyound's Avatar
enriched&beyound
Just to clarify....does this do it when turning left and right?, or just when changing directions, forward to reverse and vise-versa?
DO you have your foot on the brake when changing directions? F to R, and R to F? It maybe that you have a slight vacuum leak. Vacuum line to the brake booster , was it changed or checked too?
Doubt that bad belt would cause a hesitation, as you put it stutter...more likely a bad bearing if its lugging it down. Try this....with the engine off, slip the Serpentine bet off. Then spin the individual belt driven components listening and feeling for drag and roughness. With key on and engine off, turn the A/C on and off as well, testing how free the A/C compressor turns for each. Yes with it on it should turn stiffer but not ragged or rough.
Another thing to check is that the heater hoses are not leaking on the rearward most spark plugs.
66with352
1997 - 2003 F150
Jul 1, 2016 09:16 AM
jfowler1
Jul 7, 2012 08:27 PM
70shovelhead
2004 - 2008 F150
Nov 26, 2007 09:59 AM
scraprat
Jan 8, 2005 07:36 AM
