Power Problems...
Old Aug 4, 2015 | 10:16 AM
dieselgrl's Avatar
dieselgrl
Power Problems...
Hello all -
This is my first post and I am hoping that I could get some pointers in the right direction...
My baby, a 93 F-250 7.3 IDI diesel is having some power problems. As in she has no power!
I had her out the other day and I was able to start her fine, and then the next try, she had no power what so ever. I was unable to get any of the typical start up lights, and needed to use a jump to get started.
I am thinking either a short somewhere, or a blown fuse.
Anyone have any other suggestions?
I appreciate all your input in advance...
A couple of points of information.
1. The batteries are about 3 years old.
2. The starter is about 2 years old.
3. Alternator... I haven't seen the typical slow loss of power when an alternator goes out, when its not recharging the batteries.
4. We checked the battery terminals, and they seemed fine, no corrosion to speak of.
Old Aug 4, 2015 | 12:48 PM
Chris Hawkins's Avatar
Chris Hawkins
check your battery cables and the wires on the fender solenoid I believe there are fusible links there which may have burnt in two. this could cause the no power issue.
Old Aug 5, 2015 | 11:52 AM
tjc transport's Avatar
tjc transport
i ain't rite
welcome to FTE. age of parts does not really mean anything.
you need a multimeter to test the voltage at the batteries before starting and after starting with engine running, this will tell you what is really going on.
Old Aug 6, 2015 | 02:02 PM
dieselgrl's Avatar
dieselgrl
Thanks Chris and tjc -
We did some diagnostics at home with a multimeter and found that the battery terminals are having some issues. Looks like I'll be replacing them soon!
The multimeter showed ~12.6 on the battery posts and ~14.3 (approx) on the terminals, though the terminals showed different readings on different locations on the terminal.
Thanks again for the input!
Old Aug 6, 2015 | 04:35 PM
tjc transport
i ain't rite
ok. 14.3 on the running side means the charging system is working. change out the battery connections, and make sure you check that the ground connections are good too.
tr0y
Apr 8, 2015 09:47 AM
airmac20
1997 - 2003 F150
Jun 17, 2011 11:04 PM
jaspirr
May 12, 2009 10:01 PM
jimbo beam
Feb 28, 2008 10:14 PM
themtb
Electrical Systems/Wiring
Jun 10, 2006 12:23 AM
