hello everyone im having some trouble putting these 844 springs in my 95 f150 I got the old springs out and where the new spring is thicker I cant get the upper spring retainer to go in the spring and get the top bolt hole to line up any advice?
I just changed my old springs to Moog springs on my 94 F150. I didn't have any issues (except the new springs were too long to get in without a spring compressor) so all I can suggest is to adjust the position of the spring. Maybe a hammer to help it seat? I had to use a hammer on one of mine. All it took was a millimetre or two and it fit right in.
The length isnt much of an issue for me cause all i did was drop the front suspension and put the spring in and jacked it back up ill take some pictures later and post them
Well it went it guess it just needed some tweeking ha did you have to buy new alignment bushings? Which ones would you recommend? I know fully adjustable but which ones?
Glad it went in for you. I didn't need to get new alignment bushings as my truck was sitting like so / \ before the swap and now it looks like | |
If I did need alignment bushings I was going to get the Moog adjustable ones. I'm not sure what the part number is.
FWIW I was able to get the drivers side spring changed without a spring compressor but my suspension just wouldn't drop far enough to get the passenger side in. I even disconnected the shock.
