Basic Question
Old Aug 1, 2015 | 10:48 PM
53flathead's Avatar
53flathead
Basic Question
I have a 72 F-100 with a 2V 289 from a 67 Bronco currently in it. I am gonna rebuild or replace. I have found a complete 2V 1970 351 W and I'm considering purchasing it for the replacement. Should everything be a direct swap? I am hoping to have the replacement engine built and ready before I pull the 289. I know they are both small-block but just don't want any surprises if I can avoid them.
Thanks in advance.
Old Aug 2, 2015 | 12:49 AM
Conanski's Avatar
Conanski
The 351 is a different block than the smaller 289/302 but they are in the same engine family and all use the same engine mounts and belhousing bolt pattern so it will swap right in there.
Old Aug 2, 2015 | 02:02 AM
sawmaned's Avatar
sawmaned
the 70 351w is a very good strong engine,alot of torque,a good comp cam 268 will wake this motor up a lot even with a 2bbl,i built 1 and ran it in a 75 Granada I raced ,
Old Aug 7, 2015 | 07:31 AM
Motorhead351's Avatar
Motorhead351
Your exhaust will likely need to be modified, especially if your using a Y pipe. But nothing major.
UMDSmith
16
Apr 16, 2019 08:50 PM
jmacr12
Aug 11, 2012 11:00 PM
89cutomf150
Feb 1, 2006 12:26 PM
Brad 61
Apr 11, 2005 02:08 AM
ban_dit68
Aug 17, 2003 04:14 PM
