Ok....now what?
Old Jul 30, 2015 | 08:42 PM
voodoolord's Avatar
voodoolord
Ahh I see. Im surprised that wasn't done when they did all this engine work. Should I do this after checking if I have straight up timing or before?
Old Jul 30, 2015 | 08:43 PM
redroad's Avatar
redroad
Give this a read
I would do both at the same time if you can otherwise you'll be fine tuning the motor twice ..
Old Jul 30, 2015 | 08:44 PM
bkaul's Avatar
bkaul
If you're not running EGR, you may need to back off the advance a bit to avoid knock (with EGR, the timing is more advanced to make up for the lower flame speeds). If it's not knocking under load though, I wouldn't worry about that level of detail for now.
You said it was running OK when the vacuum line was off the carb, meaning you may've had a vacuum leak at the time? Could it be that you tuned the idle mixture to compensate, and it's off now that the leak is corrected? Is the problem only at idle (running OK off-idle), or is it problematic everywhere?
Old Jul 30, 2015 | 08:47 PM
voodoolord's Avatar
voodoolord
Ya I got that. I didn't know that the lack of a EGR would effect the vacuum advance. I cant imagine that they had all this work done and didn't address a serious issue with the vacuum advance.
Old Jul 30, 2015 | 08:51 PM
voodoolord's Avatar
voodoolord
I tuned it with the vac adv on for the carb idle screws. It fell off somewhere while driving. I cant remember it running bad after I finished the carb tuning but now it is with the vac on. Very strange.
redroad's Avatar
redroad
I'm really kind of excited about your project because I've been seeing van 4x4 rolling chassises coming up for sale and would alwais pass because I thought the bodies we're limited to 73-79 .. Now that I know the bodies til 91 will fit it makes a project like that a lot more doable .. The wife and I like to do back country camping and a 4x4 van is the ticket with a high single axle trailer
Old Jul 30, 2015 | 08:53 PM
voodoolord's Avatar
voodoolord
Hell ya! I was thinking about buying another 78 that is for sale here just because. Im probably going to put a class B camper body on this chassis. Ill definitely do a writeup on the build.
Old Jul 30, 2015 | 08:55 PM
voodoolord's Avatar
voodoolord
and its 75 to 91. pre 74 was unibody. Its obviously better to get as late as possible for newer metal and less wear. 92+ is absolutely way too much work to fit on a pre 91 so that's out the door.
Old Jul 30, 2015 | 08:57 PM
redroad's Avatar
redroad
Like I said here ..
It also could be your initial timing is to far advanced already ..
Old Jul 30, 2015 | 08:59 PM
redroad's Avatar
redroad
Where you live you should have no problem getting goood metal .. I flew to Portland to buy my 87 F350 crewcab and drove it home to western Pa.
I was really surprised how well sheet metal holds up out there ..
Old Jul 30, 2015 | 09:01 PM
voodoolord's Avatar
voodoolord
So Im good with leaving the adv plugged until I get this worked out? Right?
Old Jul 30, 2015 | 09:06 PM
redroad's Avatar
redroad
Yes or just retard the timing til no ping ..
Old Jul 30, 2015 | 09:13 PM
  #28
redroad's Avatar
redroad
BTW I did the straight up timing set and distributor recurve on my 87 F350 460 crew ..
1) I got better and more power where I needed it
2) better throttle response
3) better gas mileage
Old Jul 30, 2015 | 09:25 PM
  #29
voodoolord's Avatar
voodoolord
Ya I know the benefits. Luckily someone had already done that on my 85. That truck runs great and has almost an identical setup as the van.
Old Jul 30, 2015 | 09:33 PM
  #30
redroad's Avatar
redroad
Sorry for repeating myself I just realized we had talked on one of your other threads
