Redhead box update
Old Jul 30, 2015 | 04:57 PM
F-250 restorer's Avatar
F-250 restorer
Redhead box update
Anyone have probs with their product?
Old Jul 30, 2015 | 05:32 PM
HIO Silver's Avatar
HIO Silver
Nope.. she fit like a flesh tuxedo.
What a pain in the azz to ship back though... 42 honkin' pounds! I lined my box with a thin piece of chip board so it wouldn't fall out the bottom.
Old Jul 30, 2015 | 06:06 PM
PA F250's Avatar
PA F250
They shipped me the wrong one at first. Got it sorted out and installed fine. Letting it sit over night to bleed as advised so haven't tested yet. Shipped the wrong one back to them the same way they shipped to me. USPS flat rate box for $17.95 or so. They reinforced the bottom and all corners with an extra layer of cardboard before shipping.
Old Jul 30, 2015 | 07:49 PM
voodoolord's Avatar
voodoolord
No issues, works great.
Old Jul 30, 2015 | 07:58 PM
Eli1644's Avatar
Eli1644
I loved it. Still have some air trapped but every time I drive my truck turning to the right gets easier. Definitely gonna go back to them when it comes to gearbox
Old Jul 31, 2015 | 01:38 AM
co425's Avatar
co425
I am not running the stock box but my red head saginaw box works just fine. Even with the over pressured 1600 psi cummins saginaw pump.
Old Aug 7, 2015 | 02:15 PM
F-250 restorer
I don't want to cast a shadow of suspicion on a good product, so I thought I needed to elaborate about my question. I installed my Redhead box 17 months ago. When I got under it it looked as though the pitman shaft was flexing.
Upon inspection, with the box out, I found, and should have noted upon original install, that the bolt holes were enlarged. I welded in new tubes and now box sits tight, no wobble, and the steering is as new.
RedHead is a great product.
Old Aug 7, 2015 | 07:58 PM
PA74F250's Avatar
PA74F250
How much play do you think you have between the input and output of the gearbox?
Old Aug 7, 2015 | 08:05 PM
PA74F250's Avatar
PA74F250
Reason I ask is I simply cannot find anything other than what I found several years ago with their box. At the time of the video I just completed my D60 swap and everything was new and I mean everything. The last piece of the puzzle was ditch the sloppy box I was given with the D60 so I bought a redhead. I probably don't have 2k miles on that box to this day. Real kicker is I have a $400 79 F250 I've been piecing together with whatever I can find and it steers awesome
I sent this to them back then they said its normal so that's where it ended.
Old Oct 29, 2015 | 10:06 PM
F-250 restorer
I hate to say it, but for all the time it took to get the redhead box, and the extra expense, I will say that it was not worth it. For the box to have a wobbling shaft after less than 18 months?
I'm really disappointed to seek what is supposed to be the best, and it turns out to be about the same as an Auto Zone $100 rebuild ... that disgusts me.
Even if I pursue a warranty (which is 1 year) I don't want to be w/o for the extended length of time. If you can't get it right the first time then something is wrong.
Old Oct 30, 2015 | 11:11 PM
tbear853's Avatar
tbear853
Stuff happens and nothing made by man is 100% .... but I put my Red Head Steering Box in my '77 in December 2012 and there is no slop in it, the steering is still GREAT ...... and that's some better than it was when I bought the truck in 1986 with all of 35,xxx miles on it.
Old Oct 30, 2015 | 11:31 PM
winginit's Avatar
winginit
i put a rebuilt box from nappa for $150 2 years ago and it works great in my 74 flatbed
Old Oct 31, 2015 | 07:38 AM
78 PEB's Avatar
78 PEB
I put a O reileys $150 box in my '78 and its just as sloppy as the one I took out. The only thing I gained is it doesn't leave a puddle in the garage. Time for a Redhead.
Old Nov 1, 2015 | 09:22 AM
1995F150XLT4x4's Avatar
1995F150XLT4x4
My Redhead box has never given me any issues. Been installed for over a year now.
Old Nov 1, 2015 | 11:55 AM
Roger Carter's Avatar
Roger Carter
Was your steering gear centered, or "straight ahead" when you checked for the play? By centered, or straight ahead, I mean the steering gear has to be in the center of it's travel. This is best checked with the drag link disconnected from the pitman arm.
Just because the wheels are going straight doesn't mean the steering gear is centered.
A properly adjusted steering gear should have no, or minimal, play when "straight ahead". However, the more the steering gear is turned, the greater the play. This is in the design of the gear.
