5.0 Explorer slight engine mods
Old Jul 30, 2015 | 12:38 PM
DeereFord300's Avatar
DeereFord300
Ive been looking at a 2nd gen Explorer for my son and came across a 5.0 AWD model. I usually hang over in the 80-97 forums where most of the trucks are set up with the speed density EFI system and are usually not very accepting of any small engine mods. But anyway, is the EFI system in these 5.0s very adaptable to say, a cam swap? Valve/lifter work? Thx in advance
Old Jul 30, 2015 | 02:00 PM
85e150's Avatar
85e150
Conanski in the sbf forum has the goods on these. Iirc 1.7 rockers are a very cheap and easy mod. More later
Old Aug 1, 2015 | 10:39 PM
DeereFord300
Bump. Nobody has touched a late model 5.0?
Old Aug 1, 2015 | 11:26 PM
85e150's Avatar
85e150
Post 3 & 5:
https://www.ford-trucks.com/forums/7...rer-5-0-a.html
I tried a bit more of a search but didn't hit an Explorer thread. Exhaust is the first step, and gearing is often mentioned.
Do you know if this engine is MAF or SD EFI? MAF accepts mods, SD is very limited.
Old Aug 1, 2015 | 11:47 PM
85e150's Avatar
85e150
Header and exhaust threads, maybe others. Good luck.
Modified 1995-2001 Explorers - Ford Explorer and Ranger Forums "Serious Explorations"®
Most of what I found here at FTE has to do with F150 302s. The upgrade for those wheezers is Explorer heads and roller cams. Since you are already there with the heads, then the Explorer motor upgrades go to Mustang parts. Since you are already at 205-215 HP, the Mustang stuff isn't going to do a lot, but then you are looking for slight mods.
Old Aug 2, 2015 | 12:23 PM
DeereFord300
I believe they are all MAF, but they are more sophisticated than the MAF F-series
Thanks for all the help/links
Old Aug 17, 2015 | 10:04 PM
94MustangGT's Avatar
94MustangGT
Exhaust is a big restriction on those 5.0 Explorers. A company used to make headers for them but don't anymore, maybe check out eBay for a used set.
TorqueMonsterHeaders.com
Spktyr
May 3, 2017 02:52 AM
NotEnoughTrucks2014
Nov 25, 2015 03:53 PM
OK F1
Jan 28, 2013 09:22 AM
Old93junk
Oct 6, 2010 10:48 PM
