Dual points
Old Jul 27, 2015 | 03:55 PM
Willz74's Avatar
Willz74
Dual points
What do you guys think
It's made out of a Mallory distributor idler pulley bearing from a 91 ford a piece of electrical conduit melted beer cans and an 8mm Mauser k98 barrel from ww2 other than that it's stock parts
Old Jul 27, 2015 | 04:03 PM
redroad's Avatar
redroad
Looks like a flame thrower to me Who needs Oem parts any way
bigcrunch's Avatar
bigcrunch
Looks like a magneto
Old Jul 27, 2015 | 05:13 PM
Willz74's Avatar
Willz74
I had it in the truck running but it hits the air filter so I did the easy fix and got a taller intake
Old Jul 27, 2015 | 11:55 PM
brian1080's Avatar
brian1080
What is the purpose?
Old Jul 28, 2015 | 12:53 AM
Willz74's Avatar
Willz74
The hope was to keep from filing the points so often
Old Jul 28, 2015 | 05:55 AM
gatorfor88's Avatar
gatorfor88
Thats why they designed electronic ignition.
Old Jul 28, 2015 | 08:27 AM
MixWizard's Avatar
MixWizard
You will just be filing both sets of points often.
Old Jul 28, 2015 | 12:41 PM
Willz74's Avatar
Willz74
My dad wanted the new highboy to be a bug out vehicle so points was necessary
Old Jul 28, 2015 | 12:46 PM
bkaul's Avatar
bkaul
If there's been a nuclear blast close enough to you to for the EMP to fry the transistors in an electronic ignition module, I don't think any vehicle's going to do you any good anyway.
Old Jul 28, 2015 | 04:45 PM
46Whizzer's Avatar
46Whizzer
Does the upper cylinder part not rock all around?
What is the perceived advantage over an OEM points distributor?
Why not stash a few durasparks in a faraday cage?
Old Jul 28, 2015 | 11:19 PM
Willz74's Avatar
Willz74
It's a very tight fit so it doesn't move as far as I can tell
A guy I talked to said the plastic part would wear since it is riding on long surfaces so I put shrunk the shaft .2 inches to get a lower surface speed over oem but they don't fit like that so I put them at 180 degrees instead of 135 and offset the heights .5
I made it tall to put the condenser inside it since being at 180 degrees there is no room for one the original plan was to sit it on top of the lower breaker but when I put it together it hit the rotor
And anybody can hide duraspark units but my wires fried for duraspark and the new truck is points anyway
Buzz44
Projects
13
Jan 24, 2015 02:56 AM
sand_fiend
Nov 11, 2012 12:00 PM
Sparky83
Projects
25
Nov 1, 2012 08:20 PM
Duramaxfanatic1
Ford Truck Parts for Sale
24
Jan 5, 2011 04:43 AM
