SEAT BELTS
Old Jul 27, 2015 | 12:54 PM
jvmcc's Avatar
jvmcc
SEAT BELTS
I see that Mid Fifty has a seat belt "kit" that is described as being everything I would need to get seat belts in my '53 F100. I don't see anything similar offered by the other vendors (Mac's & LMC, to name two.) Does anyone have direct experience with this Mid Fifty setup? It costs about $250. Does that seem reasonable? Am I better off just buying the interior cab corner plates for the shoulder mount belts and putting together all the rest from salvaged belts and retractors? Any comments and/or observations would be appreciated.
Old Jul 27, 2015 | 02:35 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
If you got the money it is better (IMHO) to buy the kit rather than cob together old crap from the junk yard.
Old Jul 27, 2015 | 04:35 PM
49f3dls's Avatar
49f3dls
You might want to check out to his site
Seatbelt
Military Humvee Seat Belt Kit, 4 piece - 622852, Field Gear at Sportsman's Guide
Some guys have tried them with good success. Have fun.
Old Jul 27, 2015 | 04:46 PM
lowtrkn2k's Avatar
lowtrkn2k
Seatbelt
You cant beat that price in a junk yard!
Old Jul 27, 2015 | 05:39 PM
jniolon's Avatar
jniolon
old and in the way
I just ordered this set... I only need 2... if 4 actually show up I've got a pair for sale cheap
john
Old Jul 27, 2015 | 10:04 PM
artscott61's Avatar
artscott61
Veteran: Navy
You don't know how long the junk yard belts have sat in the weather. What is you life worth. I did not go the junk yard route. They might look good but you never know. I sell fall protection belts and they are a one time use no matter how good they look.
Old Jul 28, 2015 | 01:52 AM
Björn's Avatar
Björn
bit late but this Is also a good set
Retractable 3-Point Shoulder Harness Seat Belts Lap Belts and Seat Belt Accessories - Juliano's Hot Rod Parts
Old Jul 28, 2015 | 03:48 AM
scrape's Avatar
scrape
i normally just buy a pair of retractable seatbelt with long web stalk, and the middle gets a lap belt using same principle , i then use 4" x 4" 1/8" plates with 7/16 nf nuts welded to the plate, then plug weld to the floor.
i would roll a piece of 3/16 plate to match the roll of the corner at the top of the rear window to door area, then weld nut and plug weld.
this is easy, safe and legal in Australia, so it should work in the states no problem
Old Jul 28, 2015 | 06:51 AM
topmoo's Avatar
topmoo
I agree, use new belts. I got Juliano's which meet new car specs, welded in 3/16 plate between the door posts and the window frame and used plates below the floor board.
Old Jul 28, 2015 | 07:41 AM
56panelford's Avatar
56panelford
That is what I used in my panel and will for this pickup and you have a choice of colour.
Old Jul 28, 2015 | 07:49 AM
HILLBILLY BOB's Avatar
HILLBILLY BOB
who has tried and used the military seat belts ? what are your likes and dislikes,would you buy them agin?
Old Jul 28, 2015 | 07:54 AM
56panelford
I personally don't see any problem with the military seat belts from what's shown in the pictures other than they only come in black. I'd but a pair if it weren't for that.
Old Jul 28, 2015 | 08:07 AM
mustangmike6996's Avatar
mustangmike6996
I have a set from my 1969 Mustang I might use if they fit ok. The bench seat height might be a limiting factor for me. I was also looking into the HUMVEE surplus.
Old Jul 28, 2015 | 11:28 AM
49f3dls's Avatar
49f3dls
I have not used the Surplus belts but got he link from a thread on this forum about 4 or 5 months ago. Two or three guys had purchased them and put them in. They said they worked very well and seemed very good quality. If they are ok in a military war machine I think they would be ok in our pampered old trucks. You may be able to do a search for the thread. Have fun.
Old Mar 4, 2017 | 01:34 PM
jniolon's Avatar
jniolon
old and in the way
dragging up an old post...
installed mine today and they are too short... these were for a hummer and the original retractable mount was on a raised portion of the cab (fender well I think) so you loose a foot of cable. I'm gonna use an extender on the other end and add 12-14" to the length that way..
john
