P1876 code
Old Jul 26, 2015 | 12:28 PM
carlos perez's Avatar
carlos perez
P1876 code
New member, Florida. I have a '02 F350 just over 114k miles, tow light is flashing and just had P1876 code come up. 4h and 4l engage and disengage with out a problem. Code reads 2wd solenoid circuit failure. Where is this solenoid is located?
Thanks
Old Jul 27, 2015 | 06:24 AM
projectSHO89's Avatar
projectSHO89
P1876 indicates an electrical problem with the PVH solenoid
- Check connectors both ends (PVH solenoid and GEM module for corrosion, pushed pins, etc)
- Check for 12V supply at PVH common terminal.
- PVH solenoid (check coil resistance each side to common, should be ~50 ohms each side).
- Check continuity both circuits back to GEM module.
- Replace GEM module.
Old Aug 19, 2019 | 04:26 PM
meaganmartin2012's Avatar
meaganmartin2012
Could this issue cause what feels like lugging” under load?
jcpease
2009 - 2014 F150
Feb 12, 2018 04:48 PM
7.5GasHog
Jun 19, 2014 05:30 PM
swampcritter
Aug 1, 2012 10:46 PM
dsljay
Jun 15, 2009 11:25 PM
Ted Wolf
1997 - 2003 F150
Aug 22, 2005 09:22 PM
