Manual door sticks
Old Jul 26, 2015 | 12:26 PM
AAubinoe's Avatar
AAubinoe
Manual door sticks
Hi,
While I am waiting on balljoints so I can finish my front end rebuild, I lubricated all of the door hinges and latches with white lithium grease. Made a Big difference especially on the rear cargo doors. Also replaced a missing rear plastic clip on the rear doors.
This is the final issue I am having with the doors. The driver side window sticks. This is a base model work van. Only wire going through the door jamb is for the speaker.
My first though is lube the track and cable, so I did. It did not make much of an improvement, besides operating quieter. here is the real strange thing, it works great going down, and works great most of the way back up. The last 6 inches or so going up are a real pain! Almost feels like you are about to strip the splines on the crank.
Is there any body with experience out there with these units? appears to be riveted in place, if I go through the trouble of pulling it, I might as well spend $35 and replace it and be done. let me know what you think.
Thanks
Old Jul 26, 2015 | 12:32 PM
JWA's Avatar
JWA
Fairly sure this same topic was also a question some time ago by you?
Being in the glass biz I'd guess the entire regulator mechanism---which is cable driven---is beginning to bind causing your condition.
Yes regulators are riveted to the door shell so they would need to be removed before the mechanism can be extracted. There are also two rivets holding the glass itself to the regulator, also needing to be removed. Glass can and should remain in the door shell, held in place all the way up in order to give more working room and not break the glass.
HTH
Old Jul 26, 2015 | 12:36 PM
AAubinoe's Avatar
AAubinoe
HTH
Thanks, Yeah I can see what needs to come out by looking at the replacement part. Think I better just go ahead and buy it. No use messing around with it anymore. Its probably just going to fail completely one day, only reason its been dragging on so long is that its not used every day.
Are you supposed to rivet in the new one? http://www.rockauto.com/catalog/more...nid=569&jpid=3
Old Jul 26, 2015 | 04:37 PM
vettex2's Avatar
vettex2
I've just used a bolt. The ones I've done came with one to replace the rivet(s).
Old Jul 26, 2015 | 05:33 PM
AAubinoe's Avatar
AAubinoe
ok thanks alot for the input.
joshofalltrades
16
Nov 27, 2013 09:56 AM
corbox1
Mar 20, 2011 07:52 PM
pipman76
Dec 20, 2008 09:16 PM
tylstruck
Apr 15, 2008 06:13 PM
marty_1970
Dec 8, 2003 04:51 PM
