I have a 1970 F250 3/4 Ton 2wd with, I believe, a 390. Lately I've been having intermittent electrical problems. I've traced the problem to a wire connecting to the hot side of the starter solenoid. In the attached picture it is the red wire. I replaced the quick disconnect (yellow in the picture) but that did not solve the problem. With the battery connected I can move that wire up down left right and the dome light in the cab will go on and off (with the door open of course). I have a few questions:
1. What is the black piece directly below the yellow quick disconnect? (Fusible Link?)
I think that the black thing is the juncture where the ignition, voltage regulator and alternator and possibly horn relay wires all come together to pull power from the + of the solenoid. In my opinion, that is too many wires coming together for power to be using a spade connector.
If it is a spade connector, pinch the female end to make the connection tighter, or properly splice them all together.
Hmm, I notice your Battery Positive hot cable is Black. That's Normally used for Negative ground cables. Yep LOOKS like someone done a little hack job on your wiring.
Look for loose connections at that splice red wire
Originally Ford used a red battery cable for positive, a black battery cable for negative, but in the late 1970's, replaced both these battery cables with blue cables.
I was really hoping this was not a hack. However, when I purchased this truck 25 years ago, it was setup for dual batteries and the owner did have some type of camper. Since this isn't a Camper Special I'd assume a local mechanic wired it accordingly.
I've removed some electrical tape to get a better picture. As you can see, a big thick black wire and a yellow wire enter the black jacket, and two red wires exit. I cannot find any information on the black jacket that would indicate it's a fusible link or what its amperage is. Looking at the wiring diagram it appears it is a fusible link. What does 38A mean? Also, is there a link to a colored wiring diagram?
I appreciate everyone's help, but I am at a complete loss.
I should also note that the reason I replaced the spade connector with another spade connector is because there was so little wire to work with coming out of the unidentified black jacket. I thought that if it really is a fusible link the heat from soldering could damage it.
"38A" is the circuit number.
Ya don't need a colored wiring diagram because it is already color coded...... Colors are represented by a one- or two-letter designation. If multi-colored, then the main color designation. For example, "BK" means black whereas "BK-R" means a black wire with a red trace.
Colors:
BK - black
BL - blue
G - green
R - red
Y - yellow
W - white
PK - pink
V - violet
O - orange
Yes, but I see very very few color designations on the 1970 links provided. Don't get me wrong. I'm happy to have it but color or color id's would be nice.
Matt
Colors:
BK - black
BL - blue
G - green
R - red
Y - yellow
W - white
PK - pink
V - violet
O - orange
