Airbag leveler suggestions?
Old Jul 24, 2015 | 01:09 PM
bcg's Avatar
bcg
Since my truck pretty much always has a load or a trailer attached, I spend a lot of time driving around with the squatty butt. I'd like to put a set of airbags on it but I'm not even sure where to begin or what's a good setup. I know that I want an on-board air compressor so that I can raise/lower on the fly from in the cab and I'd really like them to self-level, if such a thing exists.
Where do I begin?
Old Jul 24, 2015 | 01:14 PM
Pikachu's Avatar
Pikachu
Air ride suspension on big trucks adjusts the ride height automatically with a valve. I don't see any reason that couldn't be adapted to a pickup truck with a little thought and possibly some bracket making.
Old Jul 24, 2015 | 01:25 PM
RV_Tech's Avatar
RV_Tech
Automatic systems are already available from Air Lift.
Old Jul 24, 2015 | 01:30 PM
binuya's Avatar
binuya
Why complicate things? Keep it simple and relatively inexpensive with air bags and an on board compressor. It's easy to air up or down. I found a set of Firestone Ride-Rite air bags and and compressor with gauge/switch panel on craigslist for cheap a few years ago. The set I found mount outside the frame rails. Empty, I keep 10# psi in them. When I have our slide-in camper loaded, (about #2,800), I pump them up to 80# psi, and I'm level. It drives very well with minimal sway, considering the top heavy load. I might add, I have a full length leveling leaf spring up front.
Old Jul 24, 2015 | 04:16 PM
Dan V's Avatar
Dan V
Auto leveling, quite frankly, is AWESOME!
I have the Airlift system, but am looking at an on board tank with some sort of mechanical leveling valve.
Old Jul 24, 2015 | 05:07 PM
bcg's Avatar
bcg
Old Jul 27, 2015 | 03:10 PM
Air Lift Company's Avatar
Air Lift Company
Former Vendor
Where do I begin?
Let me know if I can help out at all!
Old Jul 27, 2015 | 07:25 PM
F350-6's Avatar
F350-6
My personal opinion would be to skip the auto leveling part and get the in cab control or the phone app control to air it up or down from the cab.
I prefer the outboard airbags for a little added stability. The Firestone's I have on my truck are inboard and when I first got them I could feel the added body roll they caused (plumbed independent).
I put airlift bags on the wifes truck. (did a little cut and weld on the brackets to make them fit the gooseneck hitch like I wanted, but overall a much better set up, and they're outboard bags.
I've got an onboard compressor and tank, but I think the easy answer is to just buy the kit with a small pump that does nothing but the airbags and can do it wireless.
Bonanza35
17
Oct 21, 2018 12:08 AM
TyWebb
6.7L Power Stroke Diesel
49
Mar 26, 2011 09:07 PM
fasthauler
Jan 12, 2010 06:05 PM
nixer
Dec 29, 2004 11:50 PM
redranger1
Jul 19, 2002 12:18 AM
