Code 41 and missing all over
Old Jul 24, 2015 | 11:20 AM
anthonym92's Avatar
anthonym92
my 88 f150 with a 5.0 is missing bad (driving my 86 for now) pulled injectors and well the pintle caps on a lot of them are cracked really bad and some have a big pieces missing. could this cause my running lean condition. fixed my vacuum leak so code 22 is gone (thank god) but im still having a bad idle and hesitation under acceleration. it clears up after 2k rpms. anyways any insight would help. the pic isn't of my injectors but its similar to the cracking and also remember that 3 injectors have a good 1/4" missing of the cap. thanks guys. also my plugs look good so its not dumping too much fuel since they aren't fouled
Old Jul 24, 2015 | 06:53 PM
anthonym92's Avatar
anthonym92
Could this actually be the problem as well?
Old Jul 24, 2015 | 07:02 PM
timbersteel's Avatar
timbersteel
Well, what are you referring too?
The corrosion around the terminals inside and on the rotor? That looks fine and mine has been worse. I clean mine off each year and usually though, mine always seems to fire off quickly.
I just use Emory cloth and a razor to clean them.
Old Jul 24, 2015 | 08:04 PM
anthonym92's Avatar
anthonym92
both. im more concerned about the fuel injectors. and it seems that thats the only thing right now that could cause my lean condition and misfire. ive sprayed starter fluid all over and nothing. im at a loss
Old Jul 25, 2015 | 10:54 AM
rla2005's Avatar
rla2005
Fix what you know is wrong...you can get new pintle caps and o-rings to eliminate that as a cause. For that matter you should just rebuild them while you have everything apart.
Evan_P has a thread about that process.
Old Jul 25, 2015 | 08:14 PM
anthonym92's Avatar
anthonym92
i went ahead and checked out evan p's thread and i was wondering if i can use the 4 hole injectors.....seems more efficient. i will also be replacing my whinning HP fuel pump. my exhaust is loud since i have a cherry bomb on it and i cant even hear that with the pump.
Old Jul 25, 2015 | 08:25 PM
rla2005's Avatar
rla2005
New injectors cost more money with little to no gain. It's your choice.
Old Jul 25, 2015 | 08:30 PM
anthonym92's Avatar
anthonym92
oh shoot my bad. what i meant was could i use the 4 hole sprayer rebuild kit with my stock injectors?
Old Jul 25, 2015 | 08:36 PM
rla2005's Avatar
rla2005
Not to my knowledge.
Old Jul 25, 2015 | 08:37 PM
anthonym92's Avatar
anthonym92
or as evan_p put it....can i go from pintle style injectors to the DRI style injectors if i can get ahold of them for free?
Old Jul 25, 2015 | 08:38 PM
anthonym92's Avatar
anthonym92
aw darn i guess i will stick with the pintle style injectors. lookin for a rebuild kit now. kinda sad i have to take off the plenum again tired of takin that damn thing off
Old Jul 25, 2015 | 08:50 PM
rla2005's Avatar
rla2005
Nothing wrong with the single hole injector IMHO.
Old Jul 25, 2015 | 08:54 PM
anthonym92's Avatar
anthonym92
true. i will stick with them. any recommendations for the rebuild kits. can only find them without the filters
8092shrtbx
Modular V8 (4.6L, 5.4L)
May 12, 2014 01:14 AM
RacinNdrummin
35
Nov 20, 2012 12:59 AM
Johnny Be Cool
Modular V10 (6.8l)
Aug 22, 2010 05:36 PM
takotruckin
Aug 9, 2010 02:33 PM
kdagenais
Feb 1, 2008 02:03 PM
